Exhaust leak? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=19239 |
Author: | BayouStateHunter [ Mon Jun 13, 2011 5:36 pm ] |
Post subject: | Exhaust leak? |
Got my new MM exhaust in. My question is do they all leak at the slip fit where the muffler pipes meet the flange/head pipes? The flange design also will probably leak since the knurled header pipe slips fits into the flange with no gasket. My old EVT also leaked a little at the slip fit. Has anyone wrapped the pipes or slit the muffler pipe where it slides onto the header pipe and secured with a pipe clamp? Signed Sincerely, wtf? |
Author: | Robn1020 [ Mon Jun 13, 2011 6:07 pm ] |
Post subject: | Re: Exhaust leak? |
Author: | BayouStateHunter [ Tue Jun 14, 2011 2:40 pm ] |
You can feel the air blowing back on the block at the slip fit. Anyone else have this issue?? |
Author: | autogateman [ Tue Jun 14, 2011 3:19 pm ] |
yeah i put one on my buddies PD a couple months ago and it leaked at the slip fit from day one. now the tube inside the flange is rattling around also |
Author: | bradmts [ Wed Jun 15, 2011 10:15 am ] |
Yes what's up with that mine been leakin since day one and rattles. Any one else? |
Author: | WestEndAngler [ Wed Jun 15, 2011 10:35 am ] |
yeah mine leaks, could care less though it sounds 10x more bad arse ![]() ![]() ![]() It has improved thanks to the carbon build up & really doesn't rattle except in cold conditions once it heats up she sits there & doesn't move. |
Author: | craig [ Wed Jun 15, 2011 11:37 am ] |
If it has "slip on" flanges it will leak. They ALL do. |
Author: | deltaduckmaster [ Wed Jun 15, 2011 11:54 am ] |
What ever you do don't weld it !! It has to have the slip on if not to much vibration and such !! It could break something else!! The slip on are kinda like a shock !! Just my thoughts !! |
Author: | Team Camo [ Wed Jun 15, 2011 12:03 pm ] |
Author: | bayouboy [ Wed Jun 15, 2011 1:57 pm ] |
Ummmm, just me thinking out loud here but I'm thinking if someone is dumb enough to weld up there slip flange ( defeating there purpose) then they probably deserve what ever happens to it after that! Plus everyone knows that you don't weld the slip ons you have to weld the exhaust flanges to the block! Alum2/10 rods will do the trick. ![]() |
Author: | deltaduckmaster [ Wed Jun 15, 2011 2:03 pm ] |
Author: | craig [ Wed Jun 15, 2011 2:16 pm ] |
Author: | bayouboy [ Wed Jun 15, 2011 2:18 pm ] |
So, What your saying is that I should remove/ delete my last sentence? ![]() |
Author: | OwenDickeson [ Wed Jun 15, 2011 2:19 pm ] |
Shit I went and welded mine....anyone got some kinda stuff to spray on the weld or somethin to make it go away... ![]() On another note, I lost my shoes...anyone seen em? They was on my feet just a little while ago. fuk |
Author: | bayouboy [ Wed Jun 15, 2011 2:45 pm ] |
Author: | med [ Wed Jun 15, 2011 7:27 pm ] |
BSH how loose is urs? Im doing the same setup with the slip fit on mine but its a lil too loose. I have about 1/16" gap around the flange stub that bolts to the motor. I gotta figure out how to flare the end of the fitting to make it a little tighter. The stub is 1 1/8 od. Still waiting on the pipe anyhow tho. Sent from my iPhone 5 |
Author: | BayouStateHunter [ Wed Jun 15, 2011 10:54 pm ] |
Author: | med [ Thu Jun 16, 2011 2:07 am ] |
Im rigging an old bps. It may blow off the back as soon as I start it ![]() Sent from my iPhone 5 |
Author: | pooldoo73 [ Thu Jun 16, 2011 7:52 pm ] |
U could try to wrap some grafoil tape around your stubs that will smoosh and act like a gasket of sorts. We use it all the time at work on old crappy flanges that are pitted real bad and won't seal wif a regular gasket. We used it alot at the last place I worked. I will check tomorrow to c if I can get some and will let u know. |
Author: | med [ Thu Jun 16, 2011 9:25 pm ] |
Not sure if you are talking to him or me but I would be interested in trying it if you can get ur hands on some or if you know where it can be bought. Sent from my iPhone 5 |
Author: | bayouboy [ Sat Jun 18, 2011 10:55 pm ] |
If it bothers you guys that much just get some 1.5" or 2" exhaust wrap and SS bailing wire and wrap the flanges up. Even eaisier go to a smaller jet. !!!!!!"Just Joking"!!!!!!!!! |
Author: | quackconsumer [ Sun Jun 19, 2011 4:12 am ] |
Go ahead and make it a tight fit. Then get back wit us when you start breakin welds, because der is nowhere for da vibrations to be absorbed. |
