It is currently Fri Jul 04, 2025 2:15 pm
Reply to topic  [ 21 posts ]
 Which amsoil oil ?
Post Which amsoil oil ?
I don't remember
Wed Jun 15, 2011 3:35 pm
Post Re: Which amsoil oil ?
Some Rotella T-40!!!!!
Wed Jun 15, 2011 3:41 pm
Amsoil 20-50 motorcycle oil is what I use.
Wed Jun 15, 2011 3:57 pm
I went with the 5w30XL
18x54 xtreme huntdeck 35gtr
camo designs custom paint
Wed Jun 15, 2011 4:14 pm
Wed Jun 15, 2011 4:24 pm
i'v been using series 3000 5w-30 as long as i can remeber. but amsoil just came out with a new blend called z-rod which is specifically used for flat-tappet cam shafts.
here's a link to it if you're interested http://www.amsoil.com/storefront/zrt.aspx
Wed Jun 15, 2011 4:28 pm
MMT Moderator
I'm a preferred customer some are dealers on here if I can help with price let me know. Not looking to make anything my cost etc
GTB 1860 w/ 2019 GTR40XD-HO
Wed Jun 15, 2011 5:35 pm
Rotella in mine.
Wed Jun 15, 2011 7:46 pm
I have 5-30 mobil1 in my kohler cause thats what I ran in my 31 but then I saw where it needs 10-30 because of the hydro lifters so i guess im going to change mine out.
Sent from my iPhone 5
1850 & 36pd
Thu Jun 16, 2011 2:10 am
Any oil with alot of Zinc will be what you wanna run. COnventional, or synthetic is up to you. I run Rotella. or any Diesel oil with a good zinc package.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Jun 16, 2011 5:53 am
Upon further research here is what i found. IDK if it is 100% accurate but its good enough to make a good assumption.
http://www.binderplanet.com/forums/show ... ostcount=4
Here is just a few to post up to show the zinc PPM
Amsoil HDEO 5w40 = 1081 PPM of zinc
Amsoil MC/Vtwin 20w50 = 1281 PPM of zinc
Chevron Delo 15w40 = 1622 PPM of zinc
Mobil Delvac 1300 15w40 = 1702 PPM of zinc
Rotella T 15w40 = 1555 PPM of zinc
Just stating the obvious. My motor has rotella in it cause at the time I ran that in my Diesel truck. I now run Delvac 1300 cause of price and its a great oil too, so thats what will go in the Vanny next oil change.
Bayou Surface Drive
337-351-0362
Thu Jun 16, 2011 6:08 am
Whats the deal with the zinc?
1850 & 36pd
Thu Jun 16, 2011 7:32 am
Bayou Surface Drive
337-351-0362
Thu Jun 16, 2011 7:35 am
Thu Jun 16, 2011 7:36 am
and dont forget a oil that is recomened for a motor that has a turbo, and that means high temps. so air cools run at higher temps to!!! so i think a diesel oil is the way to go for oil!!my 2 cents
Thu Jun 16, 2011 4:19 pm
From the Amsoli web site here is what is recommended.
Four-Cycle
AMSOIL Formula 4-StrokeĀ® 10W-30/SAE 30 Synthetic Small
Engine Oil (ASE) and 10W-40 Synthetic Motor Oil (AMO) use
potent detergent and dispersant additives to keep contaminants
suspended in the oil and away from metal parts long after
the additives in conventional oils have depleted. The superior
protection they offer keeps mower, tiller, lawn tractor, sweeper
and other four-cycle engines clean, easy to start and running
smoothly. Even in severe service, daily-use commercial applications,
AMSOIL Synthetic Motor Oils resist thermal breakdown
and maintain a durable lubricating fi lm on engine parts.
I run the HDD in my 04 Duramax that is the highest quality Diesel Motor oil Amsoil sales.
I run the ASE 10W30 in my Skag 27hp Kholer lawn mower. This mower has 1540 hours on it with no issues mechanical issues, still going strong.
If your going to buy Amsoil now is the time there is a sharp price increase July 1st.
Russ
Mon Jun 20, 2011 8:27 pm
Is there a specific place that you have to buy it or does az and orielly's carry it?
1850 & 36pd
Mon Jun 20, 2011 10:06 pm
Easiest way is to use this link or order directly from the amsoil web site.
Here is the dealer locator. http://www.amsoil.com/locator/dealerlocator.aspx
I have run it in my Duramax for 20,000 miles between oil changes. I have around 135K on it and no issues. It did start using a little oil at 20K so I now just change every 15K.
The Skag has been severely used in the Dallas heat for 6 or more hours a day at times. I mow vacant lots on the side for extra cash. Yesterday I mowed a lot with 4 feet jhonson grass. I'm very impressed with the 27hp Kholer on the Skag which is exactly the same as the horizontal version on many MM's.
Russ
Mon Jun 20, 2011 10:46 pm
Can u use the oils that are high in zinc for regular motor or is it mainly for racing/high performance engines. I know this is just a lawn mower motor but I would like to use the best oil if possible.
1850 & 36pd
Tue Jun 21, 2011 1:06 am
YOu are wasting money changing your amsoil at 15k. I run 10k on Rotella/ mobil delvac. You were better off with the 20k and stretching to 25k with oil analysis. Synthectic oils really dont help protect the engine longer... just the oil itself last longer needing to change it less.
Bayou Surface Drive
337-351-0362
Tue Jun 21, 2011 5:43 am
Synthetic oils don't break down like conventional oils do. They mainly become contaminated with exhaust blow by and fuel that gets past the piston rings as well as contaminants from the metal of the block and such. Long haul truckers runn it over 50K at times by using multifilter systems and sending in an oil analysis every 15K miles or so till the report comes back that you need to change the oil.
Anybody else have a kholer with over 1500 hours on it with no mechanical issues. I think that speaks for the value of Amsoil. Mobile 1, Rotella and Royal Purple are all good oils, I've tried them but the Amzoil seems to have done the best for me.
Russ
Tue Jun 21, 2011 8:31 pm
Users browsing this forum: No registered users and 150 guests
