It is currently Thu Apr 09, 2026 5:08 pm
Reply to topic  [ 25 posts ]
 Lost RPM's
Post Lost RPM's
Went out ffor a little ride today amd the motor started running at top speed 29.0 3900 RPM's which i was running 4000 RPM's at 31.7 the other day. After a little while the boat felt slugglish looked at my RPM's I was only turning 3400 RPM's max now out the water u am only turning 3200 RPM's and 3100 max in water....I have 35 GTR hoyts stage 1 set up? Any idea what can be going on the motor has only 5 hours on it?
18x60 Center Console 35 GTR
Fri May 01, 2009 6:14 pm
Post Re: Lost RPM's
Sounds like it is lonesome to go see Hoyt again...
Wants Stage II ???
Eat - Sleep - Hunt ! ! !
Fri May 01, 2009 7:07 pm
Post Re: Lost RPM's
Small adjustment to the sprang thang to me !!! Call Hoyt and git "dialed" in ...... you should be jumpin' all over 4k !!!!
GoodLuck !!!!
Fri May 01, 2009 9:27 pm
Post Re: Lost RPM's
Yea, the only thin I can image is that they key is sheared?????????.......All i have is the GT shop # if anyone has a way of getting in touch wit hoyt please PM me the # I know they in Iowa for that demo deal
Fri May 01, 2009 9:53 pm
Post Re: Lost RPM's
IS the motor hard to start? does it take a while for it to pop off? that would be the first sign that the key is sheared,
Fri May 01, 2009 10:02 pm
Post Re: Lost RPM's
Yea it does have trouble starting that is why i thought it could be a sheared key
Sat May 02, 2009 8:20 am
Post Re: Lost RPM's
Sat May 02, 2009 3:08 pm
Post Re: Lost RPM's
Rumble, it's the bracket that is holding the throttle cable that is cracked. Briggs changed something in their bracket and they started cracking. Call the shop we made a fix for this last week, and we will ship you one out. ;)
Sun May 03, 2009 8:03 pm
Post Re: Lost RPM's
17x48 extreme stage 2 GTR
Sun May 03, 2009 8:25 pm
Post Re: Lost RPM's
Sun May 03, 2009 8:32 pm
Post Re: Lost RPM's
does the motor spin over for a long time before it cranks up, and when it does do you almost have th feather the throttle?
Sun May 03, 2009 8:38 pm
Post Re: Lost RPM's
Sun May 03, 2009 8:39 pm
Post Re: Lost RPM's
its the timing key.
Sun May 03, 2009 8:47 pm
Post Re: Lost RPM's
Sun May 03, 2009 8:50 pm
Post Re: Lost RPM's
The timing key is the problem behind the hard to start issue,the low rpms may be what was mentioned earlier about the cracked bracket.
Sun May 03, 2009 8:53 pm
Post Re: Lost RPM's
Sun May 03, 2009 8:56 pm
Post Re: Lost RPM's
Sun May 03, 2009 8:58 pm
Post Re: Lost RPM's
Sun May 03, 2009 9:01 pm
Post Re: Lost RPM's
Sun May 03, 2009 9:04 pm
Post Re: Lost RPM's
Sun May 03, 2009 9:15 pm
Post Re: Lost RPM's
From what I read, the key is supposed to be for alignment only, not intended to hold the flywheel (the bolt does that). Huh, Learn something everyday.
Mon May 04, 2009 5:06 am
Post Re: Lost RPM's
Lap the flywheel to the crank before you install the timing key, also stick a toothpick in the gap alongside the key if present. Once the flywheel is torqued down it isn't going anywhere without a puller.
Mon May 04, 2009 8:05 am
Post Re: Lost RPM's
Went to the GT sho yesterday and it ended up being the broken bracket on the throttle assembly....The guys fixed it up and it is good to go....
Tue May 05, 2009 8:02 am
Post Re: Lost RPM's
Does any one have detials on this broken bracket condition? A pic would be great. Just to help identify it.
Wed May 06, 2009 1:07 pm
Post Re: Lost RPM's
1754 GT w/ 35 GTR Hoytafied
Wed May 06, 2009 1:15 pm
