35 hyperdrive not charging
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=19369
Author:  Christop73 [ Sun Jun 19, 2011 11:44 am ]
Post subject:  35 hyperdrive not charging
Motor is brand new 3hours run time. Anything I can checkout before I haul it to the dealer?
Author:  richard nagon [ Sun Jun 19, 2011 12:26 pm ]
Post subject:  Re: 35 hyperdrive not charging
when u hooked up the power leads did maybe some one hook them up backwards ? all it takes is a second. also these engines don't show a good charge till u get to about 2000 rpms.
Author:  T-Bubba [ Sun Jun 19, 2011 12:32 pm ]
make sure the yellow wires on the side of the block with the plugs are pluged in tight.
its a CDI right?
Author:  POKER1 [ Sun Jun 19, 2011 12:39 pm ]
You check it with a meter?
Author:  Christop73 [ Sun Jun 19, 2011 1:44 pm ]
It's not a cdi motor. I checked with a meter, voltage does not rise at all at no matter what the rpm's are.
Author:  dog walker [ Sun Jun 19, 2011 1:49 pm ]
there is a plug that can burn up and cause this but if that's the case it would be better to bring it back to the dealer anyway. It's the clear or white harness plug around the starter, atleast thats where it is on a gtr and gd
Author:  POKER1 [ Sun Jun 19, 2011 2:15 pm ]
Unplug the regulator and look at the plug. There is usually some sign on the plug when it goes. About $100.00 for the part unless its under warranty.
Author:  Christop73 [ Sun Jun 19, 2011 2:29 pm ]
Checked both the plugs on the side under the cover, both look brand new no sign of arcing or anything burnt. With the motor running should I have voltage coming into the regulator?
Author:  POKER1 [ Sun Jun 19, 2011 2:53 pm ]
Can't help you on which wires to check coming into the regulator. Where you located?
Author:  Christop73 [ Sun Jun 19, 2011 2:56 pm ]
Davenport Iowa
Author:  POKER1 [ Sun Jun 19, 2011 2:59 pm ]
Yeh, thats a little far for a road trip. I keep an extra regulator handy along with other spare parts.
Author:  Christop73 [ Sun Jun 19, 2011 3:05 pm ]
LOL! At least it'll be warranty work, but still a pita.
Author:  POKER1 [ Sun Jun 19, 2011 3:18 pm ]
Author:  pokey79 [ Sun Jun 19, 2011 7:46 pm ]
on the 2 yellow stator wires u should have no less than 26 volts AC with the motor runnin at 3600 rpm!!
Author:  Christop73 [ Sun Jun 19, 2011 8:39 pm ]
26 volts at each yellow or do I need to run a jumper between the two to get the 26v?
Author:  postalpaul [ Sun Jun 19, 2011 9:45 pm ]
No jumper--unless you Want fireworks
26vac one meter lead on each, is what I'm reading.
Is your battery brand new??
Author:  pokey79 [ Mon Jun 20, 2011 8:51 am ]
put ur red meter lead on one yellow and ur black lead on the other yellow and put meter on ac volts!!!!!!
Author:  Christop73 [ Mon Jun 20, 2011 11:26 am ]
Battery is brand new, I recharged and load tested it. The batt is good. I will see what voltage I have coming out of the yellow wires. Hopefully it's just the regulator.
Author:  Christop73 [ Mon Jun 20, 2011 4:26 pm ]
So I have 26 volts coming outta the two yellow's. So this means the regulator is junk?
Author:  pokey79 [ Mon Jun 20, 2011 5:29 pm ]
disconect the red wire from the regulator and check dc volts with engine runnin at 3600 and if u have good volts u need to make sure that the red wire is hooked up behind the key switch it would be the single wire plug on the key switch!!!
Author:  Christop73 [ Mon Jun 20, 2011 8:00 pm ]
Red wire is secure on the key switch. With the motor turning 3600 rpm's I have 13 volts coming outta the red wire of the regulator. With the key on motor not running I have 13 volts too. I think my regulator is not regulating anymore.
Author:  pokey79 [ Tue Jun 21, 2011 6:41 am ]
ok check volts at the little orange wire that goes to the solenoid of the starter with the motor running and then let me know where u at with that!!! if u wondering im just tryin to eleminate the key switch as ur problem!! Because the red off the regulator goes to the key and then it goes to the orange wire postion which goes back to the starter solenoid where ur battery positive is and thats what charges the battery!!
Author:  Christop73 [ Fri Jul 01, 2011 9:22 pm ]
Battery was hooked up backwards when I picked it up from the dealer. The wire coming off the back of the starter had red shrink on that end then black shrink on the other end. Same for the ground wire, it had black shrink on the engine end then red shrink on the batt side.
Author:  duckman [ Sat Jul 02, 2011 2:29 pm ]
If you disconnect the orange wire from the start, how much voltage should be there. when the motor is runnin 3600 rpm
Author:  pokey79 [ Sun Jul 03, 2011 5:33 pm ]
it depends if u have the 20 amp charging system or the 50 amp charging system but it should be a little more than 13.0 and up!!!!
