It is currently Thu Jul 03, 2025 4:51 pm
Reply to topic  [ 7 posts ]
 Engine mods for running with a load
Post Engine mods for running with a load
I am running a 31hp mb with the single carb, exhaust and 12.25 big blade upgrade on a 2054 gatortrax. The boat runs ok with 2 guys and a hunting load but add a 3rd man or more load and we are on the slow boat. Any suggestions (other than the obvious upgrade to the 7000) gearing , different pitch prop etc.
Thu Jun 30, 2011 7:41 pm
Post Re: Engine mods for running with a load
Iron mountain heads, then maybe a cam if u want more
"Insert gay tapatalk signature here"
Thu Jun 30, 2011 7:48 pm
U don't need the roller rockers or push rods
Thu Jun 30, 2011 7:49 pm
What is your RPM with load right now?
Do you know your current gear ratio (lower gear size)?
Fri Jul 01, 2011 5:13 am
As far as performance parts goes, I would start with Iron Mountain heads, and add a cam if you still arent satisfied. That is provided that you dont have a problem with the hull (hooked) and your propeller is in good shape.
And, with the larger Gator Trax boats, they will handle a large load well however weight distribution is just as critical as if you had a smaller boat. Have you tried moving people/gear around in the boat (as far back as possible) to see how that changes how she performs?
Fri Jul 01, 2011 8:12 am
Yes tried shifting the load every which way. As far as gearing they are the stock gears. And I need to get a new tach to see the RPM the one I have now went on the fritz last season. If I had to guess I would say approx 3800 to 4000 loaded.
Fri Jul 01, 2011 4:24 pm
Fri Jul 01, 2011 5:42 pm
Users browsing this forum: No registered users and 131 guests
