craig
 Back up and running
I finally put it all back together and went for a a ride yesterday. This engine is probably one of the smoothest running stage 3 engines I've seen. I can turn the idle all the way down to 450-500 rpms with it still running smoothly. Top end speed seems to be about the same as before....I didn't have a GPS to clock it so I'm not real sure what i was running. As for bottom end...thats where this thing shines. I replaced the cheetah cam with the EVT 493f cam and now the hole shot on this thing is stupid! With the engine trimmed down it jumps on step like a regular outboard without bogging down...instead of needing to cavitate for 100 ft. What I like most about this engine is that I have all this power and my compression is under 200 psi. Now I'm gonna advance the timing a little bit just to give the throttle a little extra crispness.
Sun May 08, 2011 8:51 am |
Woodiebuster
 Re: Back up and running
Put up some video of that low idle.
Sun May 08, 2011 9:08 am |
OwenDickeson
How fast you was running before?
Sun May 08, 2011 10:30 am |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
Sounds good dic!
Sun May 08, 2011 11:00 am |
deltaduckmaster
 Back up and running
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Sun May 08, 2011 11:09 am |
craig
Sun May 08, 2011 1:22 pm |
craig
Sun May 08, 2011 2:31 pm |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
 Back up and running
Engine sounds awesome!!!
Sun May 08, 2011 2:51 pm |
dpd
Joined: Thu May 07, 2009 10:25 am Posts: 714 Location: Thibodaux, LA
Engine does sound smooth. Question for you onthe mikuni. Do you have to warm up the engine for say about 3-5 minutes with the choke engaged before you run, or were you able to get her tuned where you can crank and run? I think I have mine tuned pretty well but I need to let it warm up for a few minutes or else it's temperamental.
_________________ 16 x 48 Blanchard Bateau / 40 PD FPR Eat,Sleep, Fish, Hunt. Repeat.
Sun May 08, 2011 4:18 pm |
deltaduckmaster
 Back up and running
I have never had go let it warm up or choke mine!!
Sun May 08, 2011 4:40 pm |
craig
 Back up and running
Sun May 08, 2011 5:04 pm |
deadbird8
Sun May 08, 2011 6:17 pm |
craig
 Back up and running
Sun May 08, 2011 6:36 pm |
Pooh Bear
Joined: Wed Jan 14, 2009 10:43 pm Posts: 612 Location: Everywhere.USA
Congrats Bro.....
_________________ Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Sun May 08, 2011 7:37 pm |
cb5331
Congrats man. Glad you finally got some time to get that thing back together.
Sun May 08, 2011 8:22 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Sounds good Craig. Damn nice speeds too. When you gonna come down and run wallisville? You can even bring your big headed step brother.
Sun May 08, 2011 8:36 pm |
craig
Sun May 08, 2011 8:44 pm |
caddobrook
Hey man if you don't mind would you post everything you have done to your motor.
I know you have tried some different things and just went back to stock on some things and am curious where you landed on everything.
Thanks.
Sun May 08, 2011 8:53 pm |
craig
Sun May 08, 2011 9:02 pm |
Woodiebuster
When do the valves start to float?
Sun May 08, 2011 9:05 pm |
craig
Sun May 08, 2011 9:07 pm |
Robn1020
Sun May 08, 2011 9:12 pm |
craig
Correct.
Sun May 08, 2011 9:25 pm |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
Glad to hear your back up and running. I have to agree with ya on the 493f cam. I'm glad I called and asked ya about that when I was changing mine out. That cam is a monster on the low end
Mon May 09, 2011 6:05 am |
MaXXis85
What kinda RPM's you expect to turn on the top end? You plan on keeping them under 5k?
Mon May 09, 2011 6:56 am |
craig
Mon May 09, 2011 7:05 am |
MaXXis85
Mon May 09, 2011 7:13 am |
cb5331
Have you got to run this thing much? I was curious how hard you've been on those stock connecting rods and if they seem to be taking the high rpm's pretty well.
Also, are you not doing any port work on the heads?
Sat Jul 09, 2011 1:06 pm |
craig
Mon Jul 11, 2011 9:04 am |
cb5331
Any particular reason for not doing any port work?
Good deal on the rods!
Mon Jul 11, 2011 9:46 am |
craig
Mon Jul 11, 2011 9:50 am |
cb5331
I thought that may be the reason.
Mon Jul 11, 2011 10:01 am |
craig
 Back up and running
I'm not gonna just "grind" away at a set of heads, more than likely doing more harm than good. Some supposed performance guys around here market there heads as being "ported and polished" but have no f-ing idea if what they're doing is actually helping. But hey, at least they look pretty.
Mon Jul 11, 2011 11:37 am |
bayouboy
Congrats my boy, that thing is crazy smooth!
Mon Jul 11, 2011 3:04 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
Trapper's in lockport might have a flow bench!!! He does alot of head work there!! 985-532-5655
Mon Jul 11, 2011 4:26 pm |
cb5331
Mon Jul 11, 2011 4:59 pm |
drake1
Silkpower figured out his port and polish work by using a flowbench. That is also how we figured out the gen was not flowing as well as the Briggs on the exhaust side.
Tue Jul 12, 2011 5:47 am |
