It is currently Sun Jul 06, 2025 5:03 am
Reply to topic  [ 24 posts ]
 Tiny Tach
Post Tiny Tach
That ditch went out on me at about 65 hours
36 PD FPR on a PD X-Series 18X54
Tue Jun 28, 2011 4:00 am
Post Re: Tiny Tach
For some reason I've gone through a few of myself
Tue Jun 28, 2011 4:03 am
Post Re: Tiny Tach
Do they put the hours back on them or just give you a new one?
Tue Jun 28, 2011 4:11 am
Post Re: Tiny Tach
You just get a new one.
Or you could keep the old one and....
Just write your desired RPM's on it with a Sharpie
Tue Jun 28, 2011 4:15 am
Post Re: Tiny Tach
Tue Jun 28, 2011 4:19 am
Post Re: Tiny Tach
Be sure to write down your hours for future dic measuring purposes,you'll thank me later.
Tue Jun 28, 2011 4:50 am
Post Re: Tiny Tach
Jesse told me you can send your old one to tiny tach and they will send a new one with the correct hours
I gave up mud motors
Tue Jun 28, 2011 5:10 am
Post Re: Tiny Tach
i had problems with one too. i called tiny tach and they said it was prolly too many wraps on the plug wire, that all it needs is one wrap.
try this
peel label off front, you will see a rectangle cut out of the plastic that is filled with gray rubber. take a pocket knife blade and stick it straight down into the far right side of the rubber rectangle. it will contact a copper ring inside and reset the unit. your hours will be reset to zero. put label back on.
i did this and used only one wrap on the plug wire and now it works perfectly.
Tue Jun 28, 2011 7:15 am
Post Re: Tiny Tach
Most of the time...when these units "go-out" prematurely it's due to a short in the ground wire. Cut it back as short as possible. (removing all excess slack)
Tue Jun 28, 2011 8:16 am
Post Re: Tiny Tach
Cant hurt to try
Tue Jun 28, 2011 8:44 am
Post Re: Tiny Tach
Wed Jun 29, 2011 4:43 am
Post Re: Tiny Tach
How would one go about resealing it?
Wed Jun 29, 2011 5:59 am
Post Tiny Tach
Fail... Looks like I'm going to have to send it off. I don't think the warranty will cover it now lol
Wed Jun 29, 2011 5:08 pm
Post Re: Tiny Tach
call them first, you have to really stick the blade deep into the rubber stuff for it to make the contact. the ttech support guy that toldd me how to do it was really helpful. call them when youre right in front of the tach.
Wed Jun 29, 2011 5:10 pm
Post Tiny Tach
Wed Jun 29, 2011 5:44 pm
Post Re: Tiny Tach
same thing
Wed Jun 29, 2011 6:21 pm
Post Tiny Tach
Soooo I became fed up with the little Piece of crap. So I tried one last thing
And it worked!!! It bolted right on!!!
Haha
Thu Jul 07, 2011 7:15 pm
Post Re: Tiny Tach
:lol: :lol:
that hole you see in the circuit board is where you have to stick the knife blade in to reset it, just for future reference.
Thu Jul 07, 2011 7:21 pm
Post Tiny Tach
I had found it but it just wouldn't work. I proly wasnt doing it right lol
Thu Jul 07, 2011 7:36 pm
Post Re: Tiny Tach
Yeah, I always did hate it when I hit the hole wrong, but it usually only took a second to fix that. :mrgreen:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 07, 2011 7:49 pm
Post Tiny Tach
Hahaha boy I set that one up lol
Thu Jul 07, 2011 7:52 pm
Post Re: Tiny Tach
Ok so mine just died at 65 hours as well ???
Fri Jul 08, 2011 8:17 am
Post Re: Tiny Tach
A hammer will fix that!!! :lol:
Fri Jul 08, 2011 8:37 am
Post Re: Tiny Tach
Ok so i did not take a hammer to it but i tapped pretty hard on her and now it says 222c what the hell is that does it mean it is shot ??? I have not did the knife into it to reset it it is riveted on but will try if ya all think that will work
Mon Jul 11, 2011 2:47 pm
Users browsing this forum: No registered users and 124 guests
