HELP! evt exhaust parts question
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=19956
Author:  louie louie [ Tue Jul 12, 2011 5:57 pm ]
Post subject:  HELP! evt exhaust parts question
I have a evt exhaust on a 35 gatortail and the support [ u know the one in the middle that is banded on] one of the legs that helps give it support broke off. I called the guy that owns or use too own evt and he said the company in ohio that use to make parts for him might have some, but they didnt; does anyone know where i might find this part. Also on 2 of the allen screw holes where the pipes bolt to the engine the threads have been smoothed out, not sure if it was from vibration from losing the support or something the previous owner did.[ ive only had the motor a couple of months] any solutions? And last when i pulled the exhaust off they were no gaskets, should there be?
Author:  craig [ Tue Jul 12, 2011 6:00 pm ]
Post subject:  Re: evt exhaust parts question
You'll more than likely have to get something fab'ed up.
Yes...you should of had gaskets there.
Author:  retired and broke [ Tue Jul 12, 2011 6:10 pm ]
Post subject:  Re: HELP! evt exhaust parts question
On the bolts try getting some about 10 mm longer, the longer ones will catch more threads in the head and they don't have to be allen heads
Author:  Brinkleydog [ Wed Jul 13, 2011 6:59 am ]
where you located?
You might have not asked the right question....ask the owner if he has any parts on any of the blown up motors out back!
Thats should get you some parts.
PS...tell him Brinkley dent you :twisted:
Author:  take'emgator [ Wed Jul 13, 2011 8:26 am ]
Send some pics of what your dealing with so we can get a better idea, might be a simpler fix
Author:  T-Bubba [ Wed Jul 13, 2011 8:35 am ]
he is talkin about this bracket
Author:  take'emgator [ Wed Jul 13, 2011 8:37 am ]
It didn't show up T-Bubba, must be my computer
Author:  louie louie [ Wed Jul 13, 2011 9:22 am ]
Thanks for the pic man, that is the bracket im looking for; anyone know where I can get one?
Author:  Ruddyduck [ Wed Jul 13, 2011 9:44 am ]
That bracket doesn't really factor into the strength of the muffler. I ran mine quite a while with out and had no problems. If it bothers you and you really want one, send me the dimensions and I'll make you a piece that will fit. It was explained to me that that piece is to keep the uprights from pulling during the welding process and has no bearing on the strength of the muffler.
THe stripped hole is more of a concern. Hopefully the longer bolt takes care of the problem.
Author:  pooldoo73 [ Wed Jul 13, 2011 11:05 am ]
That bracket is the only thing that holds an evt exhaust on. The flanges loosely fit on. Without that bracket, u don't have a muffler back there.
Author:  louie louie [ Thu Jul 14, 2011 3:11 pm ]
Thanks for all the replies im gunna run it without the bracket for a while and see how it goes. thanks again!
Author:  MaXXis85 [ Thu Jul 14, 2011 3:33 pm ]
Author:  cb5331 [ Thu Jul 14, 2011 3:43 pm ]
The old exhausts had fixed flanges, not slip on's.
Author:  Ruddyduck [ Thu Jul 14, 2011 5:03 pm ]
R u missing the 1" x 6" strap that connects the two mounting brackets together or one of the mounting brackets that bolts to the motor? Makes a big difference!
Author:  dog walker [ Thu Jul 14, 2011 5:18 pm ]
When running it just keep an eye on it. I had the long brace break as well as one of the arms that bolt on to the back of the motor. With one of them broke you will start having more stress and vibration on the other.
Author:  louie louie [ Thu Jul 14, 2011 6:31 pm ]
Im missing one of the supports that bolts to the motor. I ran it last nite and it seemed like it did ok with jus one support; and i think i figured out how i lost the support; last night that side of the exhaust was shooting a light flame and that whole side of the exhaust was cherry red; which caused me to shear the head off another bolt where the exhaust flange bolts to the motor. I was told that the valves may need adjusting; has anyone had this promblem?
