It is currently Mon Jun 23, 2025 8:40 pm
Reply to topic  [ 10 posts ]
 Anybody seen this oil leak spot?
Post Anybody seen this oil leak spot?
Noticed this couple weeks ago when changing my clutch
Anyone else ever seen oil sheen/leak in this spot on 36 Vert?
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Wed Jan 14, 2009 5:14 pm
Post Re: Anybody seen this oil leak spot?
Case gasket
Wed Jan 14, 2009 5:31 pm
Good eye Rivers !!!! I thank the bolt on the left needs just a little tightn' up and you be good to go.
Wed Jan 14, 2009 6:49 pm
every time i go out i see that.........good luck.
I'm going to tie mine to each other then i get time to drill pilot holes for the wire.
How many minutes can u run before you have to tighten you bolds? it get about 12-40 min...................I HATE CASE GASKETS..............
Thu Jan 15, 2009 10:25 am
When you tear it down to replace the gasket you need to stud
the base bolts & use lock nuts thay hold better
the studs you will need are 8mm x 1.25 x 70mm
seems to work well in the testing we have done :D
Thu Jan 15, 2009 11:41 am
That sounds like it might be a winner Silk!
Sat Jan 17, 2009 10:04 pm
If you want to just take the bolts out one at a time and put new lock-tight on them. did this on all the bolt i could get to (without taking anythign off) and it held for 5 hours this weekend. Im going to take the pipe off today and get that one.
DO NOT DO THIS MORE THAN A FEW TIME YOU WILL STRIP OUT THE THREADS...then you will have to stud it like Silk said.
Silk what you charge to stud a 36 pd out?
Later
Mon Jan 19, 2009 9:59 am
not too worried bout it right now got barely a week left in season then will be goin back to them to get some more put into the motor and have gasket changed
Pete Willett
Mon Jan 19, 2009 10:23 am
I've run a case gasket leak all season and just watched the level. Run about 20 hrs and it hasn't gone down much. I'll fix it when I get around to it in the off season. 8-)
Mon Jan 19, 2009 6:13 pm
Just run thicker oil. :lol:
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Fri Jan 23, 2009 7:24 am
Users browsing this forum: No registered users and 109 guests
