It is currently Thu Jul 10, 2025 6:41 am
Reply to topic  [ 16 posts ]
 Help! Tate-down questions
Post Help! Tate-down questions
I'm wanting to pull my cam out. I have the motor only sitting on my bench. No heads front cover or all the other bs. What comes of next? Flywheel or rear case?
Sat Jul 16, 2011 7:45 pm
Post Re: Help! Tate-down questions
Assuming it's a briggs or assembled in a similar manner, the rear case. Don't have to take the flywheel off to pull the cam.
Sat Jul 16, 2011 7:53 pm
Yes Briggs 29. Rear cover does not want to come off. Removed the bolts and it only pulls off 1/2 inch
Sat Jul 16, 2011 8:07 pm
How long has it been sitting up?
You may have some burrs on the crankshaft. Take an emery cloth and smooth it up a bit and see if that helps. If there is any surface rust or burrs it will catch on the seal on the way out. Make sure you clean it well so you don't scar the bearing on the other side of the seal.
Sat Jul 16, 2011 8:11 pm
Sat Jul 16, 2011 8:52 pm
Push the cover back on and use a fine emry paper on the end of the crankshaft. it should slide right off aftr that.
BUCK OFAMA
Sat Jul 16, 2011 8:56 pm
Didn read every post. Sorry CB.
BUCK OFAMA
Sat Jul 16, 2011 8:57 pm
Sat Jul 16, 2011 9:03 pm
I used a three prong puller hooked to three bolts screwed into auxiliary holes in the cover.
Sat Jul 16, 2011 9:06 pm
After you clean it with emry cloth shoot a squirt or two of 3 n 1 oil or some type of lubricant to help with friction.
Sat Jul 16, 2011 9:10 pm
Then if it still doesnt want to come off, tap it in a circle around the cover with the butt of a screw driver while you pull on it.
Make sure your pulling straight out and its not in a bind.
Sun Jul 17, 2011 8:46 am
Still can't get it off. It comes about 3/4" off the block then stops. It's like there's a hidden bolt stopping it.
Sun Jul 17, 2011 12:34 pm
Nvmind got it off. Thanks for all the help guys. Appreciate it alot. Only thing is I might have scared up the housing bushing too much
Sun Jul 17, 2011 3:57 pm
Just the seal or the metal where the crank sits? The seal is not a big deal, it's like 11 bucks and not a bad idea to replace anyway.
Sun Jul 17, 2011 4:02 pm
The bushing on the rear case.
Mon Jul 18, 2011 7:07 am
Tue Jul 19, 2011 4:19 am
Users browsing this forum: Google [Bot] and 58 guests
