It is currently Sun Oct 18, 2026 11:45 am
Reply to topic  [ 7 posts ]
 evt mikuni
Post evt mikuni
got a friend that will sell me a evt mikuni and intake for a good price. He tells me he took it off because it gave him great top speed but took away alot of his low end, and when installing the intake you have to cut off 2 air flow tabs which if you do alot if idling(bowfishing) the air would blow over the top and ran much hotter than before the kit. also, after installing the kit his idle went up to arounf 6 mph and after trying everything to get it to idle slower for bowfishing changing jets, tweaking, and constantly chaning rpm's he had enough. anyone else seem to have these problems?
im especially worried about cutting these tabs off and overheating.
17x54 custom CC with stage 3 GTR.
Sun May 10, 2009 9:09 pm
Post Re: evt mikuni
Sun May 10, 2009 9:14 pm
Post Re: evt mikuni
what do you mean by cowling? the black plastic?
Sun May 10, 2009 9:16 pm
Post Re: evt mikuni
yeah, the main air shroud
Sun May 10, 2009 9:19 pm
Post Re: evt mikuni
I would expect it would have a stable idle at lower RPM. I added a carb spacer and can idle @900 4.7mph with the stock carb. I wouldn't expect you would loose low end either, its just a more efficient carb. Maybe the guy had a gasket leak on the intake somewhere. His loss may be your gain if the kit is in good shape and a good price.
The metal cover over the shroud opening is a good idea to force the air through the heads vs coming out the top.
Mon May 11, 2009 5:57 am
Post Re: evt mikuni
sounds to me like ur source was just a little less mechanically inclined than most and couldn't tune a carb. His loss/ur gain.
Mon May 11, 2009 6:12 am
Post Re: evt mikuni
yea, iv never heard of hese problems before either, he's very mechanically inclined so maby he just did alittle too much tweaking.
Mon May 11, 2009 9:02 am
