It is currently Sat Jul 05, 2025 8:20 pm
[ 3 posts ] |
caducks21
 bps throttle lever
Does anyone know if this BPS throttle lever will work for my honda lontail?
_________________ Folded Feather Guides We'll wash 'em, if you fold 'em
Mon Jul 25, 2011 6:14 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: bps throttle lever
I believe it will fit on a 7/8" handle without having to grind anything, but you will have to put a spring on the carb to return the throttle to idle.
Sent from my Droid because I'm trying to be as cool as you someday.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Mon Jul 25, 2011 6:43 am |
Gros'bec
Joined: Sat Jul 23, 2011 11:36 am Posts: 235 Location: Louisiana
If your handle is to small, cut a piece of rubber hose the same width to match then slice the bottom of if and put it over the tiller handle. If the handle is to big, a little light grinding may be needed. I replaced the plastic one that mudbuddys come with 2 months ago because it had a crack where the set screw goes in and was loose. I know this one won't crack.
_________________ 18x44 Gator Trax, Stage 2 Mudbuddy
Mon Jul 25, 2011 9:27 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 169 guests |
