Bigger exhaust valves. Worth the $? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=20282 |
Author: | jbert22 [ Sat Jul 23, 2011 8:08 pm ] |
Post subject: | Bigger exhaust valves. Worth the $? |
Are the set of stainless valves worth the money. I'm sure it would help but are they really worth 400 bucks like on the mudbuddy site? And why can't I just replace the exhaust valves with stock intake valves to enlarge them. |
Author: | craig [ Sat Jul 23, 2011 8:10 pm ] |
Post subject: | Re: Bigger exhaust valves. Worth the $? |
Author: | jbert22 [ Sat Jul 23, 2011 8:15 pm ] |
Check out the mudbuddy site. I'd love to find some valves that cheap |
Author: | cb5331 [ Sat Jul 23, 2011 8:20 pm ] |
Pretty sure they're 110 bucks for a set of 4 from bps. If not, performance v twins has the manley's (i believe the same that bps uses) for 35 bucks a piece. EVT has ferrea's for 240 a set. |
Author: | garrettpearce [ Sat Jul 23, 2011 8:54 pm ] |
So are they worth it |
Author: | Team Camo [ Sat Jul 23, 2011 10:41 pm ] |
Are they worth $110? Definitely. Are they worth $400? Not to me. |
Author: | deadbird8 [ Sun Jul 24, 2011 5:12 am ] |
The question to ask is: what is getting rid of the stock valves and their chronic leaking seats worth? You have to also factor in the cost installation of the valves/seats. I agree with Camo |
Author: | 50fps [ Sun Jul 24, 2011 12:50 pm ] |
Author: | cb5331 [ Sun Jul 24, 2011 1:12 pm ] |
Author: | cb5331 [ Sun Jul 24, 2011 2:00 pm ] |
You know a lot more about the air flow in these engines than I do. I was just saying that I had been told the same thing that Mitch was told, by the same person. I know Al has been around for a long time and trusted what he was telling me, but I'm not knockin' what you are saying either. |
Author: | 50fps [ Sun Jul 24, 2011 5:41 pm ] |
Author: | Jamie B. [ Sun Jul 24, 2011 6:23 pm ] |
So what size intake and exhaust valves you recomend going with with a big bore motor? Thanks |
Author: | drake1 [ Sun Jul 24, 2011 7:24 pm ] |
My gen is a big bore motor. It has 39 mm intake valves and seats and a 32mm exhaust valve and seat. These are bigger than the Briggs intake and half a mm smaller than the exhaust. Both the gen and Briggs have been on the flow bench. Gen lows better on intake and Briggs on the exhaust. We had to increase the gen exhaust valve and seat and weld up the outside of the exhaust port to increase the port size and it still will not flow better than the Briggs. We are going to attempt to open the port some more and see what happens. The ports make these little motors flow. Now I have not seen a Briggs yet that pulls like the gen out of the hole and through mid range. Just a little lazy on top. |
Author: | 50fps [ Sun Jul 24, 2011 7:36 pm ] |
Author: | cb5331 [ Sun Jul 24, 2011 7:39 pm ] |
Author: | pooldoo73 [ Sun Jul 24, 2011 7:50 pm ] |
IM heads have larger exhaust valves. |
Author: | pooldoo73 [ Sun Jul 24, 2011 7:52 pm ] |
Author: | craig [ Mon Jul 25, 2011 12:17 pm ] |
Author: | Jamie B. [ Mon Jul 25, 2011 12:59 pm ] |
Thats what i was thinking, thanks Craig. |
