It is currently Fri Jul 04, 2025 1:33 pm
Reply to topic  [ 3 posts ]
 bps throttle lever
Post bps throttle lever
Does anyone know if this BPS throttle lever will work for my honda lontail?
Folded Feather Guides
We'll wash 'em, if you fold 'em
Mon Jul 25, 2011 6:14 am
Post Re: bps throttle lever
I believe it will fit on a 7/8" handle without having to grind anything, but you will have to put a spring on the carb to return the throttle to idle.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jul 25, 2011 6:43 am
If your handle is to small, cut a piece of rubber hose the same width to match then slice the bottom of if and put it over the tiller handle. If the handle is to big, a little light grinding may be needed. I replaced the plastic one that mudbuddys come with 2 months ago because it had a crack where the set screw goes in and was loose. I know this one won't crack.
18x44 Gator Trax, Stage 2 Mudbuddy
Mon Jul 25, 2011 9:27 am
Users browsing this forum: No registered users and 178 guests
