evt pistons
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=20386
Page 1 of 2
Author:  garrettpearce [ Wed Jul 27, 2011 5:40 pm ]
Post subject:  evt pistons
can you use stock rods with the evt pistons (standard bore flat tops)
Author:  craig [ Wed Jul 27, 2011 5:45 pm ]
As long as the wrist pin diameter is the same. Get with mike or silk to verify.
Author:  garrettpearce [ Wed Jul 27, 2011 5:47 pm ]
Post subject:  Re: evt pistons
ight do you know how much compression i could expect with those pistons and .60 heads
Author:  cb5331 [ Wed Jul 27, 2011 5:48 pm ]
Prolly too much! lol
Are you shaving the stock pistons or purchasing an aftermarket flat top? If shaving the stockers, I believe you'll want the longer rods.
If your going through all that work, why not go big bore? I have a feeling craig could steer you in the right direction if you want to go that route. I think you'd want to go back to stock heads though.
Author:  garrettpearce [ Wed Jul 27, 2011 5:49 pm ]
i have a friend that is going to give me the flat tops for free
Author:  craig [ Wed Jul 27, 2011 5:51 pm ]
Author:  cb5331 [ Wed Jul 27, 2011 5:56 pm ]
Author:  garrettpearce [ Wed Jul 27, 2011 6:01 pm ]
the pistons came with evt rods stock length
Author:  craig [ Wed Jul 27, 2011 6:12 pm ]
Author:  garrettpearce [ Wed Jul 27, 2011 6:24 pm ]
thanks craig
Author:  garrettpearce [ Wed Jul 27, 2011 6:25 pm ]
also have access to dual carbs whats yalls thought on them
Author:  craig [ Wed Jul 27, 2011 6:38 pm ]
Author:  deltaduckmaster [ Wed Jul 27, 2011 6:46 pm ]
What do you have now!!
Author:  garrettpearce [ Wed Jul 27, 2011 6:49 pm ]
I have a stage 1 with stock carb but this is going to be a semi play motor
Author:  autogateman [ Wed Jul 27, 2011 6:53 pm ]
i got a set of extended length evt rods for sale
Author:  garrettpearce [ Wed Jul 27, 2011 7:33 pm ]
Don't think they'll work for my application
Author:  deltaduckmaster [ Wed Jul 27, 2011 7:34 pm ]
Author:  garrettpearce [ Wed Jul 27, 2011 7:51 pm ]
so what do you recommend i have the stage one for reliability but i want something with a little more with semi reliability
Author:  deltaduckmaster [ Wed Jul 27, 2011 9:12 pm ]
Is your timing advanced!! Bro if I was you I would stay with the stock pistons
Author:  take'emgator [ Wed Jul 27, 2011 9:18 pm ]
why you say stay with the stock pistons
Author:  garrettpearce [ Wed Jul 27, 2011 9:22 pm ]
so i have the mikuni in the shed what else could i do to give it more pep. it will have cam heads exhaust and mikuni
Author:  craig [ Wed Jul 27, 2011 9:27 pm ]
Author:  garrettpearce [ Wed Jul 27, 2011 9:32 pm ]
what does a stage 2 have?
Author:  craig [ Wed Jul 27, 2011 9:44 pm ]
Author:  garrettpearce [ Wed Jul 27, 2011 9:55 pm ]
but they are flat tops which gives you more compression right?
Author:  craig [ Wed Jul 27, 2011 10:26 pm ]
Author:  garrettpearce [ Wed Jul 27, 2011 10:28 pm ]
i was under the impressin that these pistons were flat tops and the rist pins were raised ie giving it more compression
Author:  DMC [ Thu Jul 28, 2011 3:12 am ]
Author:  garrettpearce [ Thu Jul 28, 2011 8:50 am ]
i think im just going to let someone look at wha ive got and go from there. just need that a little more ya know.......thats what she said lol
Author:  drake1 [ Thu Jul 28, 2011 9:29 am ]
You will be over 200 psi on compression with those pistons. Deck height was raised with those pistons along with removing the dish. Fastest motor I built had those pistons with .030" decked heads. 1854 GTB ran 40.6 mph.
Author:  garrettpearce [ Thu Jul 28, 2011 10:59 am ]
so in other words it probably wont last to long with heads shaved .050
Author:  drake1 [ Thu Jul 28, 2011 8:05 pm ]
Don't run every where at 5 grand and it may last a little while.
Author:  garrettpearce [ Thu Jul 28, 2011 8:43 pm ]
I'm just confused I have a stage one but want more and anything more is going to blow up. There must be something that will give you more and will be half ass "safe"
Author:  deltaduckmaster [ Thu Jul 28, 2011 8:53 pm ]
It's a money game !! Pay to play
Author:  craig [ Thu Jul 28, 2011 9:29 pm ]
Author:  garrettpearce [ Thu Jul 28, 2011 9:54 pm ]
I understand you have to pay to play but Im not going to waste my money on something I know for a fact will blow up in ten hours
Author:  Beadlejuicejr [ Fri Jul 29, 2011 4:52 am ]
I've put money on worst odds
Author:  deltaduckmaster [ Fri Jul 29, 2011 5:38 am ]
Their is enough research that can be done on this site !! Your money !!
Author:  MaXXis85 [ Fri Jul 29, 2011 6:17 am ]
Look at a race car motor. They make bIG power, but they either blow em up once in a while or tear em down after a few races and then fix stuff before it blows. Regardless its alot of coin to play with.
Author:  drake1 [ Fri Jul 29, 2011 10:57 am ]
What are you looking to do? Carry more weight or go fast? You want more speed then build a boat and prop for the motor you have.
Page 1 of 2 All times are UTC - 6 hours
