rangerman28
Joined: Wed Nov 18, 2009 10:25 am Posts: 24 Location: lafayette
 Carb problem
I can start the motor at my house. Leave to go put boat in water travel maybe 20 min and motor won't start. When I turn it over it pops and sputters like it is flooded can anyone please help me thanks
_________________ ranger r83vs with 175 merc ........... brother breaux 18x48 with a 36 fpr pd no mods
Sat Jul 30, 2011 8:29 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Carb problem
Are you saying after a 20 min ride on the trailer it won't start, or a 20 min boat ride it won't start? Is it running & then dies & won't start again, or after you shut it off it won't start again?
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Sat Jul 30, 2011 8:40 am |
quackconsumer
 Re: Carb problem
Sounds like it's allergic to water.
Sat Jul 30, 2011 10:22 am |
rangerman28
 Re: Carb problem
A 20 min trailer ride. I can get it started it takes about 5 mins of spinning it over and u can smell the gas.after I get it running it starts fine
Sat Jul 30, 2011 11:34 am |
quackconsumer
 Re: Carb problem
When it is running what rpm's does it idle at?
Sat Jul 30, 2011 11:58 am |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
 Re: Carb problem
Kinda sounds like ur carb float is stickin open or partially choked
Sat Jul 30, 2011 12:35 pm |
rangerman28
 Re: Carb problem
Around 900 Rpms
Sat Jul 30, 2011 4:58 pm |
russellm454
 Re: Carb problem
Sounds like a float issue to me where bouncing on the trailer is spilling over into the intake then the combustion chamber. You may also have trash in the needle but that would likely cause it to run rich on the water. Suggest you pull the fuel bowl and check the float out.
Russ
Sat Jul 30, 2011 6:43 pm |
deadbird8
 Re: Carb problem
Sun Jul 31, 2011 9:02 am |
