It is currently Wed Jul 09, 2025 6:17 am
[ 7 posts ] |
joey1919
 mikuni 42mm hsr
ok im pretty sure i need the hsr but there are a couple different ones. rear single throttle and dual front i think. which one do i need. i got a buddy thats a motorcycle mechanic and can probably find me one. next question , what else will i need besides the carb itself. this is going on a 35 briggs
Mon Aug 08, 2011 8:51 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
 Re: mikuni 42mm hsr
You will need the adapter to bolt it up to your intake unless u can fabricate one. You will also need a different needle and seat I believe.
_________________ 18'x54"CC Hanko/ 36PD
Mon Aug 08, 2011 8:56 am |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
 Re: mikuni 42mm hsr
Finding a carb is not a problem. Its all the parts to get it mounted and running right on a lawn mower motor is where the problem is.
Look at the parts diagram on the mudbuddy or BPS site and see what all comes with the kit. They are pretty much all necessary items to make the Carb run and work.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
Mon Aug 08, 2011 9:49 am |
joey1919
 Re: mikuni 42mm hsr
thanks . hey bbb what kind of speedsyou getting. my new rig is going to real similar to yours polling tower and all. got a gdsd 35 now thats going on it . going to do the same couple of mods you got. thought yours should be pretty close to what i should see.
Mon Aug 08, 2011 9:59 am |
bbb
 mikuni 42mm hsr
Wed Aug 10, 2011 6:31 am |
mudman5
 Re: mikuni 42mm hsr
-BBB, I highly reccomend going with the 3 blade prop from go devil. how do you like your marsh mellow? did you get the X? and any problems out of the carb kit yet? how much speed did you pick up with the kit?
_________________ 1854GoDevil 35HP GDSD
Sun Aug 28, 2011 12:05 am |
bbb
 mikuni 42mm hsr
Tue Aug 30, 2011 4:33 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 104 guests |
