Who sells a Mikuni drain plug? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=20786 |
Author: | bbb [ Mon Aug 08, 2011 10:18 am ] |
Post subject: | Who sells a Mikuni drain plug? |
From my other thread, the head of the drain plug was rubbing on the stock carb brace and wore a hole in the head. Its dripping every 1-2 seconds. Local Harley Dealer says they can't get it. Its not on their available parts list ![]() Not really seeing a parts store online where I can order the part. I do know the part number is TM 32/41. Maybe its JB Weld and forget it time. |
Author: | bbb [ Mon Aug 08, 2011 10:53 am ] |
Post subject: | Re: Who sells a Mikuni drain plug? |
HSR Main Jet Extender Kit Includes threaded extension tube to lower the Main Jet into a deeper, float bowl drain plug to reduce fuel starvation under full throttle acceleration and high performance applications. Part number: KHS-034 Found one of these for $25. Hoping for a $5 or < cost. |
Author: | russellm454 [ Mon Aug 08, 2011 7:17 pm ] |
JB Weld is your best friend ![]() My son busted a hole in his turbo intercooler on his Cobalt SS. He thought he was out $500 bills. He now understands the true value of JB Weld. ![]() |
Author: | bbb [ Mon Aug 08, 2011 7:22 pm ] |
JB Weld applied. Hopefully contact with gas will not break it down. I did order the extended fuel drain plug just in case. |
Author: | russellm454 [ Mon Aug 08, 2011 7:40 pm ] |
Cool if that kit includes it then you are better off. The cheapest I have found the float bowl plug is $25 |
Author: | deadbird8 [ Mon Aug 08, 2011 8:12 pm ] |
You don't need the extender but it doesn't hurt. You will have to make a new brace as the stock brace will not work with that one. Also on the original Google is your friend: http://www.kandgcycles.com/Mikuni-Corpo ... -PLUG.html |
Author: | bbb [ Tue Aug 09, 2011 6:19 am ] |
Author: | bayouboy [ Tue Aug 09, 2011 6:52 am ] |
I have 4 or 5 of the stock mikuni drain plug nuts. Your more than welcome to one of them. Most of the guys down this way have installed Yost power tubes kits. |
Author: | bbb [ Tue Aug 09, 2011 8:42 am ] |
Author: | bayouboy [ Tue Aug 09, 2011 9:27 am ] |
They claim at Yost you can gain anywhere from 1 to 5 HP by instaling it. I personally can't say I've seen that, but I can say it has improved hole shot and acceleration through out the whole throttle range. |
Author: | bbb [ Tue Aug 09, 2011 9:35 am ] |
Author: | Wilson [ Tue Aug 09, 2011 11:36 am ] |
I wonder if Andy (BoatDr) has even installed these? |
Author: | deadbird8 [ Tue Aug 09, 2011 7:30 pm ] |
Author: | deadbird8 [ Tue Aug 09, 2011 7:32 pm ] |
Author: | bbb [ Wed Aug 10, 2011 6:25 am ] |
