It is currently Wed Jul 09, 2025 8:46 pm
Reply to topic  [ 13 posts ]
 Engine Slowly Gaining RPM's
Post Engine Slowly Gaining RPM's
My buddy has a 36 PD.He just went get his valves set.Came home and the boat has lost power.He sent it back and they said one was loose so they fixed it.He got it back.Rpms out of water are good.But running before the valve set he could get his boat to about 27-28running around 4000-4050 rpms.Now he cant get it above 24mph.His rpms slowly gain as he is running but no higher than 3800.Can barely get 20 mph out of it with 2 peeps and a ice chest in the boat.He is pretty bummed.Let me know what you think.
17'6x48 Uncle J Custom 36 MAFIA
2010 36PD Hydro trim w/FPR
MarshMellow Exhaust
I MIGHT BE WRONG BUT U NOT RIGHT
Sat Aug 13, 2011 12:06 pm
Post Re: Engine Slowly Gaining RPM's
By "valves set" you mean the valve clearance? Who set them for him?
Any other work done on motor?
Any other changes/work when valves were set?
Sat Aug 13, 2011 12:34 pm
Yes the clearence and done by a PD dealer.The motor is stock.No work done other than getting the valves set.Boat ran perfect before resetting the valves.
MarshMellow Exhaust
Sat Aug 13, 2011 12:43 pm
I'd be trying to get it back to the dealer who did the work. Anything you do to try to fix it will probably void whatever warranty you may have had on the work. Basically, if you change anything they did, they are gonna blame you for the problem. Sounds to me like they did not get them set right. Not set on the right stroke or something...
Sat Aug 13, 2011 1:55 pm
Yeah, sounds like they goofed something up somewhere. I think if they're set too tight, you'll have a good hole shot, but no top end. Too loose, no hole shot, decent top end.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Aug 13, 2011 3:20 pm
sure they set them correctly- 1/4" past TDC on the compression stroke?
Sat Aug 13, 2011 4:51 pm
yes its gotta be something with that.He has brought it back 2 times and its still not right.He had them reset the first time and it started acting up.Brought it back and its still doing the same thing.He may have to find a new dealer in franklin.
MarshMellow Exhaust
Sat Aug 13, 2011 7:00 pm
Isn't Calen in Franklin?
Sat Aug 13, 2011 7:32 pm
I didn't want to say it...
Sat Aug 13, 2011 9:12 pm
Is it still covered under the Briggs warranty? You said he was a PD dealer but is he also a certified Briggs mechanic?
Sat Aug 13, 2011 9:26 pm
Yes he isa certified briggs mechanic.Idk whats wrong but gotta be with valves cause it ran good before that.He is gonna bring it back.
MarshMellow Exhaust
Sun Aug 14, 2011 12:52 pm
WHen I flattened my stock cam it would run up and then then the opr RPM under load kept falling and falling.. then it got to the point the boat wouldnt plane out.. Its a valve issue, Bring it back and get it checked out. Its probably a simple fix.
Mon Aug 15, 2011 8:14 am
alright guys finally got my boat back and come to find out it was the choke cable not letting the choke go all the way back in and keeping my engine from getting full rpm's. back in buisness now runnin 27.3 mph. thanks for all the help.
Wed Aug 17, 2011 8:25 pm
Users browsing this forum: Google [Bot] and 154 guests
