CLICKSTER
 23GTR RPM's??
OOW WOT i get about 4100 but with me (218) and my son (135) we only get IW WOT is about 3450 to 3500. is that cause of boat weight or drag or is it something else. i tilt it to the sweet spot before i start to lose speed. top speed with us in it is about 22. does that seem right for the 23GTR? Also will be adding the Mukuni to it this week!
Mon Aug 15, 2011 10:11 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: 23GTR RPM's??
All that is to be expected, your good
Mon Aug 15, 2011 11:07 am |
deltaduckmaster
 23GTR RPM's??
If your only adding the carb I can't see you gaining much!!
Mon Aug 15, 2011 11:11 am |
CLICKSTER
 Re: 23GTR RPM's??
already got exhaust already. revlimiter and all will be in the package deal. last will be IM heads next year.
Mon Aug 15, 2011 12:12 pm |
WestEndAngler
MMT Moderator
 Re: 23GTR RPM's??
Might as well get a 35HP & just slap a 25HP on it
Mon Aug 15, 2011 12:13 pm |
CLICKSTER
 Re: 23GTR RPM's??
just trying to play by the refuge rules!
Mon Aug 15, 2011 12:28 pm |
WestEndAngler
MMT Moderator
 Re: 23GTR RPM's??
Mon Aug 15, 2011 12:32 pm |
CLICKSTER
 Re: 23GTR RPM's??
its still a 23cubic inch engine and prop will be 9 inches!
Mon Aug 15, 2011 12:37 pm |
Chadb1010
Joined: Wed Jan 12, 2011 7:26 pm Posts: 221 Location: SETX
 Re: 23GTR RPM's??
i aint scared ill be in there somewhere
_________________ SOLD Uncle J 4x4 edition with a Stage 1 GTRRRR
Mon Aug 15, 2011 3:10 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
 Re: 23GTR RPM's??
If the GW stops u 4 any reason and sees the exhaust/carb, u will likely get cited 4 over power. Check the regs close. we got a letter from landowner about any mods 2 a 35 hp would b immediate termination of lease. And they would b checking. U can hide heads and cam, not so much for the carb R exhaust. Fine may b worth the risk. Fine may b $500 r more.
_________________ 18'x54"CC Hanko/ 36PD
Mon Aug 15, 2011 3:20 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: 23GTR RPM's??
I have a Mud buddy and i used to turn 4100 out of water and 3750 with about the same weight and now it turns 4400 out of water and 4170 with same weight. Im sure the gearing is a little different between the two but i wouldnt think the rpm would drop that much. What are the rpm with just you in it?
Wed Aug 17, 2011 3:49 pm |
