It is currently Thu Jul 10, 2025 2:19 am
[ 4 posts ] |
browndog1
 mikuni carb help
Any idea what would be causing the throttle arm on my mikuni to not return all the way? Idle will be about 1100 and sometimes it will just get stuck at 1400 on its way back down then you have to reach back there and close it the rest of the way with your hand. put wd40 on the springs and made sure that the cable on there was long enough so that it would be able to return all of the way.
Tue Aug 16, 2011 3:31 am |
deadbird8
 Re: mikuni carb help
Spray Corrosion X down your cable to lubricate it (let it run all the way through it). Also lubricate the pulley the cable rides on going to the carb throttle.
Tue Aug 16, 2011 5:47 am |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
Heres a couple more things to look for if the cable checks out okay.
Too much throttle cable tention, easiest way to check is remove the cable from the carb sheave and see if it returns all the way closed on its own.
Or if you have recently cleaned your carb with carb cleaner it will cause the slide to stick. Mikuni sells a lube for it, but i usually just use what i have a round like 2 cycle oil.
Tue Aug 16, 2011 10:07 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Mine's been doin the same thing, even with the cable disconnected. For whatever reason, the slide is sticking open just a lil bit. Tried carb cleaner, but sounds like I'm about to try some oil.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Tue Aug 16, 2011 11:36 am |
[ 4 posts ] |
Users browsing this forum: Google [Bot] and 117 guests |
