Battery
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=21213
Page 1 of 2
Author:  greg f [ Sun Aug 21, 2011 12:00 am ]
Post subject:  Battery
For a 36 PD could a larger motorcycle battery be used to start the motor? I was wondering cause it's alot less weight to carry than a standard deep cycle marine battery.
Author:  TURBODRIVE [ Sun Aug 21, 2011 12:05 am ]
Post subject:  Re: Battery
get a stinger
Author:  bayouboy [ Sun Aug 21, 2011 10:43 am ]
It would make a great back up, other than that I wouldn't trust it.
Author:  ibfishin [ Sun Aug 21, 2011 3:26 pm ]
I am trying to decide what size batteries I need as well. Trying to go as light a possible without breaking the bank. Probably going with Deka brand.
One will be for engine, bilge, and running lights.
The other will be for stereo, swamp lights, winch.
Author:  deltaduckmaster [ Sun Aug 21, 2011 3:29 pm ]
I run the smallest car battery Walmart has, have had no issues
Author:  Tenpoint [ Sun Aug 21, 2011 6:26 pm ]
Author:  greg f [ Sun Aug 21, 2011 9:03 pm ]
Thanks guys....Appreciate the input.
Author:  stualaska [ Mon Aug 22, 2011 10:48 am ]
I've run Sam's club garden tractor batteries for years with no problems. On long trips I do take a spare battery because I'm old and forgetful. If you leave a key or bilge pump on overnight it won't matter much what size your main battery is and you will be happy you have a spare. I also carry a cheap set of jumper cables in my "possibles" box. So far I've only needed them to start others, but my chance is coming.
Author:  Will [ Mon Aug 22, 2011 11:30 am ]
Author:  cb5331 [ Mon Aug 22, 2011 11:34 am ]
Different charging systems.
Author:  Will [ Mon Aug 22, 2011 11:46 am ]
O, can you tell me what the difference is? I'm curious now...
Is it that the motorcyle recovers the charge at a faster rate?
Author:  cb5331 [ Mon Aug 22, 2011 11:52 am ]
I'm not familiar with the charging system on a bike, but know for certain it is different than the one we have on our engines. The cdi motors have a decent charging system 20a at idle on up to 50a at full output. The older engines have no output at idle and I think around 20a at full output. I believe the stator on a bike is inside the block, where ours is mounted outside under the flywheel, but I am not familiar with their output ratings.
Author:  deltaduckmaster [ Mon Aug 22, 2011 11:54 am ]
The clutch alone draws 20 amps!! So if your idling alot and using trim auto reverse it can draw a battery!!
Author:  cb5331 [ Mon Aug 22, 2011 11:57 am ]
Author:  deltaduckmaster [ Mon Aug 22, 2011 11:59 am ]
If I remember right Hoyt told me that but I could be wrong.
Author:  cb5331 [ Mon Aug 22, 2011 12:03 pm ]
I'd go put a meter on mine, but don't really want to now. Over 10amps will pop my meter. lol I've been told somewhere in the 4-10 range. 20amps is a pretty hefty draw.
Author:  russellm454 [ Mon Aug 22, 2011 12:30 pm ]
Actually I think the charging systems on a H-D are very simular to that of a MM V-Twin. This article explains the H-D charging system. http://www.harleyhowto.com/forum/showthread.php?t=338
I do however think that the H-D charging system may have a higher amperage output than that on a MM. I just put a new battery on my Fatboy and you would be amazed at the price. $87 and that was the cheapest one I could find. One from Harley is around $125+ so I'm not sure that there is any cost savings going with a motorcycle battery, weight savings yes.
Russ
Author:  greg f [ Mon Aug 22, 2011 4:48 pm ]
The compression on alot of custom harleys is way more than a MM. My friend has a BMW touring bike and that thing has everything imaginable on it.....sat radio, cd player, air suspension, ect, so I figured it might work on a MM.
Author:  deltaduckmaster [ Mon Aug 22, 2011 4:55 pm ]
It is 20 amps.
Author:  cb5331 [ Mon Aug 22, 2011 5:17 pm ]
Author:  greg f [ Mon Aug 22, 2011 5:47 pm ]
Would a smaller battery have enough power to turn the motor over.
Author:  cb5331 [ Mon Aug 22, 2011 5:52 pm ]
Author:  POKER1 [ Mon Aug 22, 2011 6:02 pm ]
Author:  ibfishin [ Mon Aug 22, 2011 8:23 pm ]
So it sounds like I should get a small auto starting battery for the motor and a small deep cycle for the accessories?
Author:  Will [ Tue Aug 23, 2011 4:17 am ]
Author:  UNCLE-J [ Tue Aug 23, 2011 5:21 am ]
Author:  deltaduckmaster [ Tue Aug 23, 2011 5:30 am ]
I text Hoyt to make sure that is what he told me !! 20 amps
Author:  MaXXis85 [ Tue Aug 23, 2011 5:39 am ]
http://www.messicks.com/Articles/Fixing ... lutch.aspx
Second paragraph. Seems like they draw aboout 3.5 amps ISh
Author:  MaXXis85 [ Tue Aug 23, 2011 5:50 am ]
http://www.ganos.com/electricclutchtesting.pdf
Another link, this one is showing about 4 amps of current draw.
Author:  cb5331 [ Tue Aug 23, 2011 7:15 am ]
Author:  CaptCameltoe [ Tue Aug 23, 2011 8:43 pm ]
GD's don't have those clutch drainin the battery problems at all..........jus sayin :mrgreen:
Author:  Snowbird [ Wed Aug 24, 2011 8:43 am ]
Author:  Crook Chene [ Wed Aug 24, 2011 1:58 pm ]
I have two batteries. I keep a small lawn mower battery in the bow for a backup.
My engine burned a plug and quit charging my battery and eventually drained it. I was lucky because I was very close to my camp.
the day before I was in lillies two feet high about two miles from the nearest bayou and almost turned my motor off several times while scouting for ducks, glad I didn't- I would have been like chuck!
always bring a spare.
Author:  greg f [ Wed Aug 24, 2011 10:06 pm ]
Thanks for the input guys
Author:  keys1222 [ Thu Aug 25, 2011 4:54 pm ]
i have a deep cycle battery thats the size of a tractor battery. might be something to look into
Author:  Chico80x [ Thu Sep 01, 2011 10:40 pm ]
I'm running a Group 24 hybrid marine Deep Cell/ Cranking battery from auto zone that's been great. I've had a set for 3 years in my offshore boat that are still perfect.
Author:  JIMMY W [ Fri Sep 02, 2011 6:15 am ]
Get yourself a Optima ;)
Author:  MaXXis85 [ Fri Sep 02, 2011 6:17 am ]
Author:  JIMMY W [ Fri Sep 02, 2011 5:43 pm ]
Author:  Chico80x [ Fri Sep 02, 2011 7:36 pm ]
Page 1 of 2 All times are UTC - 6 hours
