35 vanguard engine problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=21508 |
Author: | Michaelbabb [ Sun Aug 28, 2011 8:46 pm ] |
Post subject: | 35 vanguard engine problem |
This my first post in search of how to fix my problem. I have a 35 vanguard that I use as a fan motor on my bowfishing boat. The motor has a electric fuel pump and regulator neither has been changed before my problem. I have cleaned the carb twice. The motor cranks great. Idles great . Run good at mid throttle. When I gap it to full throttle it bogs and black smoke and I can see gas spitting out the overflow tube. The govern isn't hooked up. Airfilter is clean. This problem came out of no where. I used it put it up then used it again and the problem started. Should I buy a new carb? Thanks for the help |
Author: | craig [ Sun Aug 28, 2011 8:48 pm ] |
Post subject: | Re: 35 vanguard engine problem |
Author: | Michaelbabb [ Sun Aug 28, 2011 8:56 pm ] |
Factory carb. I have checked the float and needle and seat all appears great. |
Author: | postalpaul [ Sun Aug 28, 2011 9:08 pm ] |
I wanna ask have you checked your valve lash?? |
Author: | Michaelbabb [ Sun Aug 28, 2011 9:12 pm ] |
No, how do I do this? Sorry I don't have much background with working internal engine parts |
Author: | craig [ Sun Aug 28, 2011 9:14 pm ] |
Pull your valve covers off and be sure that all 4 push rods are still in place. Then check to be sure that all of your valves are opening by cranking the engine over with the valve covers removed...making sure that all 4 valves are opening and closing. |
Author: | postalpaul [ Sun Aug 28, 2011 9:30 pm ] |
Choke ain't stickin is it?? The black smoke tells me too much fuel |
Author: | Michaelbabb [ Sun Aug 28, 2011 9:37 pm ] |
Please explain by the choke sticking? I can pull the choke out and push it back. Everything looks like it's working the right way? Would the choke move open at full throttle. |
Author: | postalpaul [ Sun Aug 28, 2011 10:28 pm ] |
Operate your throttle to full speed and see if your choke is affected ?? Engine running or not will do for this test |
Author: | postalpaul [ Sun Aug 28, 2011 10:29 pm ] |
Author: | Michaelbabb [ Mon Aug 29, 2011 12:17 pm ] |
I looked at my choke and looked like it could move some. I took a spring and put on the arm of the choke going into the carb. It seemed to help about 50% could it still be moving in the carb? |
Author: | Michaelbabb [ Mon Aug 29, 2011 3:20 pm ] |
Can there still be choke movement if the arm going in to the carb? After I pit the spring holding tge choke arm back it improved about 50% but still isnt great from dead stop to wot |
Author: | postalpaul [ Mon Aug 29, 2011 6:20 pm ] |
You need to do a lil diggin here, is your carb a Mikuni or stock??? The lack of response from some if the others on this leads me to believe they need mire info! I don't have a Briggs I'm just guessin at this point on thd Briggs carb Maybe one of the others will jump in |
Author: | WestEndAngler [ Mon Aug 29, 2011 6:25 pm ] |
Simple search... Read the first link then read the second. viewtopic.php?f=3&t=16355 viewtopic.php?f=3&t=17378 |
Author: | Michaelbabb [ Mon Aug 29, 2011 8:07 pm ] |
I have used the search tool before I posted. My 35 vanguard is stock. Stock carb. My govern has been bypassed to allow it to idle lower( it worked great with the govern by pass when I bought it). The problem came with not change to the set up. I put a spring on the choke arm entering the carb. After this it seemed to be 50% better. I could gap it from idle to wot and it would bog and black smoke for 30 seconds then pick up rpms and run great at top end no bog. I can gap it from mid to wot with not bog . But when I go from idle to wot it bogs then picks up |
Author: | postalpaul [ Mon Aug 29, 2011 9:44 pm ] |
I still think your dumping to much fuel in at once, how's your plugs look? Thought about changin heat range of plugs?? Air filter?? |
Author: | Michaelbabb [ Tue Aug 30, 2011 5:19 am ] |
The air filters look fine. It stock dual airfilters? Should I change these? What plugs do you suggest I run? I'm 100% agree with I'm dumping to much fuel |
Author: | Michaelbabb [ Tue Aug 30, 2011 5:20 am ] |
Would you suggest me to buy a whole other stock carb? |
Author: | bbb [ Tue Aug 30, 2011 5:54 am ] |
Author: | Michaelbabb [ Tue Aug 30, 2011 9:25 am ] |
Are the carbs on mudbuddy website for a horizontal shaft 35? If not where can I get one? Thanks everyone for their help. |
Author: | cb5331 [ Tue Aug 30, 2011 12:27 pm ] |
Author: | Michaelbabb [ Tue Aug 30, 2011 12:53 pm ] |
It has two airfilters. One inside of another |
Author: | cb5331 [ Tue Aug 30, 2011 1:05 pm ] |
You talking about the foam prefilter? You can discard that thing. Yes, the carbs on the MB site are for the horizontal 35's. You can try to contact SETX Performance or the BoatDr as well. One of them may have one in stock. |
Author: | Michaelbabb [ Tue Aug 30, 2011 2:29 pm ] |
My airbox is a black plastic cyclone looking. It has a large filer that fits inside another filter. I can get pictures. All is stock 35 briggs |
Author: | bbb [ Tue Aug 30, 2011 4:15 pm ] |
Author: | postalpaul [ Tue Aug 30, 2011 4:38 pm ] |
When you cleaned the carb did you take the jets out and run a tip cleaner through them by hand??? |
Author: | Michaelbabb [ Tue Aug 30, 2011 5:32 pm ] |
Yes sir, I have cleaned it twice |
Author: | postalpaul [ Tue Aug 30, 2011 6:00 pm ] |
Did you check your valve push rods yet?? You own a feeler gauge?? |
Author: | Michaelbabb [ Tue Aug 30, 2011 6:35 pm ] |
I went and bought a feeler gauge I'm going to have to read up on how to adjust and what to adjust too |
Author: | postalpaul [ Tue Aug 30, 2011 6:57 pm ] |
I THINK it's .004 intake and .005 exhaust 1/4 turn past TDC I THINK ..... Im not leanin towards valves though....just wanna eliminate that thought Do you have dual exhaust?? Have you pulled your plugs and looked at them see if one is more discolored than the other?? You got a hour meter on this motor? |
Author: | Michaelbabb [ Tue Aug 30, 2011 7:16 pm ] |
Yes I have dual exhaust with supertraper disc muffers |
Author: | postalpaul [ Tue Aug 30, 2011 8:14 pm ] |
The black smoke u notice more outta one pipe than the other?? |
Author: | Michaelbabb [ Tue Aug 30, 2011 8:50 pm ] |
Yes, black smoke seems to come out of one side worse then the other. |
