It is currently Wed Jul 09, 2025 1:24 pm
Reply to topic  [ 8 posts ]
 vanguard 35 with 4000 kit running problems-- watch my video
Post vanguard 35 with 4000 kit running problems-- watch my video
hello,
I am new to the forum. I have been having problems with this motor. It is hard to explain so I made a youtube video for yall to watch and please tell me what to do. http://www.youtube.com/watch?v=raHQEAyY0uY
thanks again
p.s. i will be posting on mudbuddy forum also whenever I am a confirmed member
Fri Sep 02, 2011 4:04 pm
Post Re: vanguard 35 with 4000 kit running problems-- watch my v
your main jet is to big i think or too small have to ask a mechanic
Fri Sep 02, 2011 4:07 pm
ran great when I had the 4000 kit installed by a mudbuddy performance center. that was in southcarolina to far for me to go back to. no change to jets, carb, entire setup no change
Fri Sep 02, 2011 4:11 pm
Then I'd say a clogged jet. Where are you located now? I'm willing to bet there's someone not too far away from you.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Sep 02, 2011 4:15 pm
after looking at my carb manual I expected it had something to do with the accelerator area. I just don't know enough about it to be messing with it. would any briggs and stratton repair shop be able to whip this in shape or should I be carefull who I choose? and thanks for the tip 50hptiller I will try that tomorrow. If yousent me a private message I couldn't read it for some reason.
Fri Sep 02, 2011 7:47 pm
50hptiller I got the video thanks I will try it. if it doesn't squirt who could I have clean it? or is it aeasy job?
Fri Sep 02, 2011 8:05 pm
You could pull the whole carb apart in a few minutes. The tuning manual has the exploded view.
A briggs shop will not touch a mikuni carb- maybe a motorcycle shop. Don't let them change your float valve!!! (ask SP).
Check your email on the MB Forum registration, theres also the BPS one
Fri Sep 02, 2011 8:37 pm
thanks for the help
problem solved!!!! spring on white accelerator plunger came off. reinstalled spring-- runs like a top!!!! thanks again
Sat Sep 03, 2011 11:45 am
Users browsing this forum: No registered users and 114 guests
