35 vanguard won't stay running http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=21633 |
Author: | dumbass [ Wed Aug 31, 2011 7:52 pm ] |
Post subject: | 35 vanguard won't stay running |
Hey guys new here. - have a mud buddy 35 vanguard my motor starts fine but then when I give it any throttle it bogs and dies. When it dies it will normally not restart for at least an hour any ideas?? |
Author: | Team Camo [ Wed Aug 31, 2011 7:55 pm ] |
Post subject: | Re: 35 vanguard won't stay running |
![]() Sounds like a dirty carb. |
Author: | dumbass [ Wed Aug 31, 2011 8:03 pm ] |
Also forgot to mention when I pump the primer ball its hard but no fuel goes into the filter. Than if I take the fuel line off and pump the ball there plenty of gas. |
Author: | Team Camo [ Wed Aug 31, 2011 8:16 pm ] |
Clogged fuel line? |
Author: | Quack Stackin [ Wed Aug 31, 2011 8:21 pm ] |
Had the same problem with the last outboard I had buy some SeaFoam(gas additive) and a new line for between the bulb and the filter and the filter and the engine.. Should do the trick! |
Author: | take'emgator [ Wed Aug 31, 2011 8:25 pm ] |
^^^^^do this, it should fix your problem, make sure no lines are kinked |
Author: | Team Camo [ Wed Aug 31, 2011 8:27 pm ] |
That's usually because of the crappy ethanol gas we have to buy now that's eating away fuel lines from the inside-out. If you can find a station that still sells non-ethanol, buy your boat gas there. If you can't, make sure you're running marine Stabil or something equivilant to it in EVERY tank. |
Author: | dumbass [ Wed Aug 31, 2011 8:33 pm ] |
Thanks for the help guys. I don't run ethanol gas and I do use seafoam in everytank. Went back outside 10 minutes ago and the fuel filtert filled with gas and motor fired right up. Another dumbass question here can high temp and humidity cause a vapor lock? |
Author: | Team Camo [ Wed Aug 31, 2011 8:36 pm ] |
Personally, never have experienced it, nor heard of anyone else. |
Author: | Quack Stackin [ Wed Aug 31, 2011 8:38 pm ] |
Author: | dumbass [ Wed Aug 31, 2011 8:44 pm ] |
Nope its runs fine for now its just this isn't the first time this has happened and everytime it has it has been very warm and humid out so I was curious. |
Author: | dumbass [ Thu Sep 01, 2011 3:19 am ] |
Ok guys went out to start my motor this morn before leaving to go hunt and nothing. Cranks over fine and it appears to be gettin fuel. Pull plugs both have spark. Any ideas now? So far great start to hunting season!! |
Author: | bbb [ Thu Sep 01, 2011 5:55 am ] |
Author: | bbb [ Thu Sep 01, 2011 5:57 am ] |
Author: | deadbird8 [ Fri Sep 02, 2011 8:44 pm ] |
Author: | odass [ Sat Sep 03, 2011 1:53 pm ] |
Something stupid to check is the vent on the tank. If mine is closed it doesn't run long |
