It is currently Thu Jul 10, 2025 2:20 pm
Reply to topic  [ 8 posts ]
 How high should my rpms be?
Post How high should my rpms be?
I have a 23hp vanguard and at wot in the water my tach reads 3100, and is only runnin 12 mph... Should my rpms be higher? By the way its a long tail so my speeds arent that large of a cocern however i think it should run it a little faster... Thanks for any help! New to mud motors so maybe dumb question??
1748 WC Custom 27 mini
Tue Sep 06, 2011 8:20 pm
Post Re: How high should my rpms be?
i would say that is slow for your motor and just slightly low rpms, you need to check your prop to see if it is the correct one for that motor
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Tue Sep 06, 2011 8:58 pm
What prop would you suggest? Ill check mine to see what size it is when i get home!
Wed Sep 07, 2011 2:23 pm
And my motor only runs 3500 wot out of the water
Wed Sep 07, 2011 3:35 pm
just guessing a 9x5, you can look at go devil website for a longtail that matches yours and see what they package there units with, it would be a start
12 ft 11hp longtail
Merc 225hp TR20
Thu Sep 08, 2011 10:12 pm
My buddy has the same model boat with a 24 Honda Beavertail. I think he runs 17-18 by himself and 15 with another adult.
Could be one of two issues. Prop is too big, or throttle/gov connections at the back of the motor need to be tweaked.
What was your load when you were only running 12? 6 adults?
Fri Sep 09, 2011 11:43 am
I'm running the same motor and with a small adjustment on the gov. spring and a port job on the intake manifold i turn 4100 out of the water and 3900 in the water with a load. boats doing 17 with myself, a buddy whos like 220 lbs and a little bit of gear.
23HP GO-DEVIL longtail pushing a 1750 Mike Kliebert custom
Fri Sep 09, 2011 1:46 pm
what you saying im fat
Sun Sep 11, 2011 12:52 pm
Users browsing this forum: No registered users and 107 guests
