It is currently Thu Jul 10, 2025 4:10 pm
Reply to topic  [ 16 posts ]
 Case gasket leak under warranty?
Post Case gasket leak under warranty?
Ive seen a few threads where it was mentioned the leaking case gasket was replaced under warranty. I saw one thread where I think the owner was just shipped a new gasket and another thread where the owner took his motor back to gator tail and had it replaced.
What exactly is paid for under warranty?
Should I contact Go Devil first, or go to my Briggs and Stratton dealer?
Looking for a good reason to install a cam before duck season.
Sat Sep 10, 2011 8:34 am
Post Re: Case gasket leak under warranty?
Sat Sep 10, 2011 9:20 am
I have a prodrive and had 50 hrs. on the motor, called Peck at the shop told him about it he told me to bring it in. dropped it off went offshore came back and it was completely fixed and sealed better then factory. didnt pay a dime it was all under warranty. those PD guys have great customer service as far as Ive seen Im impressed!
18x54 ProDrive boat with 36 FPR ProDrive
Mikuni, MM 2x w/baffles
Wild 'n Out!! Tear'n CHIT UP!!
Sat Sep 10, 2011 10:47 pm
Sun Sep 11, 2011 3:09 am
Talked to GoDevil and I can take it to either a Briggs and Stratton authorized repair center or to my dealer, if he is willing to work on the motor.
They did give me a new part number for the gasket and said to make sure they didn't install the old gasket.
The big questions is, should I put my stock carb and muffler back on the motor before taking it to their shop? Its a known issue that aftermarket parts are not causing so I am inclined to take it as is.
The B&S dealer said a B&S representative may have to come by the shop to authorize the repair.
Mon Sep 12, 2011 2:22 pm
You better cause once they see it like that it's over
17x48 extreme stage 2 GTR
Mon Sep 12, 2011 2:39 pm
Yes...engine mods will void the warranty!
Mon Sep 12, 2011 4:07 pm
I think the carb will void any warranty that is left.
18'x54"CC Hanko/ 36PD
Mon Sep 12, 2011 5:53 pm
Luckily I still have the old carb i can put back on, but guess I'll have to buy one of the stock mufflers from mb.
But then if they will only change the gasket and not throw the new cam on, I may just do it myself.
Mon Sep 12, 2011 6:05 pm
Buy a cam and a gasket and change it yourself!
Mon Sep 12, 2011 6:44 pm
Mine started leaking at 40 hours.
Mon Sep 12, 2011 8:26 pm
Tue Sep 13, 2011 5:51 am
Stock mine lasted 75 hours, Since modded it lasted about 20 hours or so. Its just weeping a little oil out the side of the case and keeping it wet. Unless it starts puking oil out im not worried about it. They all do it.
Tue Sep 13, 2011 6:35 am
I got 160 hours out of the gasket that was put in with mods. My last gtr, which was stock started leaking at 70 hours. I've been putting a torque wrench on it every so often, so I'm sure that helped prolong the life of my last gasket.
Tue Sep 13, 2011 6:59 am
I find if you run these motors with light loads they lasted longer!! Running heavy loads and keeping motor under stress makes them leak alot faster!! I been averaging about 100 hrs on mine but i have alot more precautions done to my motor for that!!
Tue Sep 13, 2011 7:29 am
I dont use my rig alot, but when I use it to go to the camp for a weekend, the fugger is full up.
Tue Sep 13, 2011 7:50 am
Users browsing this forum: No registered users and 106 guests
