It is currently Thu Jul 10, 2025 4:28 pm
[ 6 posts ] |
sellerc
Joined: Tue Jul 28, 2009 12:23 pm Posts: 10 Location: Lakeland, FL
 35GTR Trim problems.
I have a 35GTR which wont trim. I have replaced both relaysm, which didnt fix the problem. I then sent the pump back to Gator-tail to be rebuilt. I reinstalled the new pump and reconneted the wiring harness, the pump moved about 3" up and 3" down a total of 6 or times and now has completely quit working again. I hear clicking in the relays but I am getting no pump movement at all. Please help.
Mon Sep 12, 2011 9:50 am |
craig
The little circuit breaker is tripped. (next to the starter) Push in the little button on the side.
Mon Sep 12, 2011 10:33 am |
sellerc
 Re: 35GTR Trim problems.
I have found a box near the starter (actually green in color). It has several wires leading into it, but I can not find a reset switch anywhere on the box. Have I found the correct box? Where on the box is the reset switch? Do you have a picture?
Mon Sep 12, 2011 1:05 pm |
deltaduckmaster
If it is s newer motor their is no reset switch!! That box replaced the old ones and has a self reset!! Did you check the fuse
Mon Sep 12, 2011 1:10 pm |
WestEndAngler
MMT Moderator
If it keeps blowing like that I'm sure he has a pinched wire or something is causing it to short...
Mon Sep 12, 2011 1:14 pm |
muddawgchuck
Joined: Fri Oct 01, 2010 9:22 pm Posts: 959 Location: Spurger Tx.
Can you hear the trim trying to work? Or is it just the switch clicking you hear?
_________________ 18x54 WC custom 36PD EFI
Mon Sep 12, 2011 3:09 pm |
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 116 guests |
