It is currently Wed Jul 09, 2025 9:11 pm
Reply to topic  [ 11 posts ]
 engine break-in oil?
Post engine break-in oil?
question for you guys. after your break-in on new or rebuilt motors, what color and/or other things are you looking for when you drain the oil?
Wed Sep 14, 2011 12:15 pm
Post Re: engine break-in oil?
Make sure there are no chunks of metal in it.
Wed Sep 14, 2011 6:51 pm
k, so i ran the motor about 5 hours or so, running at different rpms for short periods and different loads. drained the oil and it came out a real dark gray color with metal flaking in it. mostly very small flaking but a few flakes the size of a pen dot when you tap it on paper. the metal flaking i assume is normal. but it was the dark gray dirty color i am concerned about. ???
Thu Sep 15, 2011 8:21 am
Wouldn't be concerened with the color. That's why you change it immediately after break in. There is assembly lube all over the place in there and it will get mixed in with the oil and cause it to darken. Also new rings can let a little bit of fuel pass before they get fully seated, which can furthur contaminate the oil. The metal shavings concern me a little, but I'd wait and see what DB8 or BoatDr have to say about it.
Thu Sep 15, 2011 8:24 am
He is probably seeing a little Sparkle in the draining fluid. Fill it up and dont look back. Seems pretty typical getting the sparkle on the first oil change. Mine was like that aswell.
Thu Sep 15, 2011 8:26 am
Or Maxxis, or Cody. :lol: Thanks fellas. I figured a lil sparkle was normal. Sounded like he had some bigger pieces in it, but you guys would know better what to look for. I've only done a couple and didn't notice much metal, but the oil was def discolored.
Thu Sep 15, 2011 9:17 am
LOl we rebuilt a Go-kart motor back in HS and that sucker always had shavings in the oil. Maybe cause the string we had to pull the throttle open more than the gas pedal would allow LOL.
Thu Sep 15, 2011 9:41 am
I have 10 hours on my engine and it's been full of metal also. It was built pretty "tight" so it's expected. ( I keep telling myself that anyway.)
Thu Sep 15, 2011 10:41 am
THANX GUYS
Thu Sep 15, 2011 11:26 am
Thu Sep 15, 2011 4:59 pm
Ehh he knew it would fuck up eventually anyways. Lol
Thu Sep 15, 2011 5:12 pm
Users browsing this forum: No registered users and 171 guests
