It is currently Wed Jul 09, 2025 8:49 pm
Reply to topic  [ 4 posts ]
 back crank case plate trouble
Post back crank case plate trouble
got a 35 mudd buddy the bolts that hold the belt housing to the bak of the motor backed out and 2 broke off in it after drilling and tapping them only one of the helicoils held in the block last week end the bolts where backing out again tried using lab metal and setting studs in it this time this worked on one was wondering if the sump on a 36 vertical will bolt up and match hate to spend 400 buck for a new one any help would be great guy thanks
16x56 epidemic slick bottom with mini 4000
Sun Sep 18, 2011 9:07 am
Post Re: back crank case plate trouble
35 and 36 sump are different. I would try this- Take the outdrive off, Make a template for the holes, and then have the wallowed holes welded up. Then you can re-drill per the template and re-tap.
Sun Sep 18, 2011 11:00 am
that was what i was gonna say. can that be done w/o tearing down the motor?
Sun Sep 18, 2011 11:11 am
db8 u wouldnt know anyone that would have a used back cover would ya
Mon Sep 19, 2011 11:10 am
Users browsing this forum: No registered users and 157 guests
