Engine Fuse Corrosion
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=22489
Author:  robertb4wd [ Fri Sep 23, 2011 9:33 pm ]
Post subject:  Engine Fuse Corrosion
Anyone had a corrosion problem on a fuse on the engine? Was getting my stuff ready tonight for a morning hunt and decided to just start my engine to check things out. Turned the key and nothing, not even a click. The trim worked fine, but nothing as far as the motor starting. After going into a panic mode, I found the fuse on the motor was very corroded. I cleaned to fuse holder and changed the fuse. Starts fine now. The fuse holder is supposed to be sealed, but it appeared to be getting very wet. I sprayed it down with some penetrating oil in hopes that this will help. Just thought I'd post this in case someone else runs into the same issue.
Author:  lastchance [ Fri Sep 23, 2011 9:45 pm ]
Post subject:  Re: Engine Fuse Corrosion
I spray cosmoline on all electrical components to keep them clean and free of corrosion. It also last alot longer than spray oil!
Author:  willett [ Fri Sep 23, 2011 9:51 pm ]
Where can u get that stuff? Also heard of some kind of "grease" like substance when putting new connections together but never knew where to get it?
Author:  cb5331 [ Fri Sep 23, 2011 9:54 pm ]
You can get the grease at any auto parts store. It's near the batteries.
Isn't cosmoline that shit they cover guns in to preserve them?
Author:  med [ Fri Sep 23, 2011 9:56 pm ]
http://www.wisegeek.com/m/what-is-dielectric-grease.htm
Author:  lastchance [ Fri Sep 23, 2011 10:12 pm ]
http://www.aircraftspruce.com/catalog/c ... s_rust.php
This is the product that I use. Hope this helps!
Author:  robertb4wd [ Fri Sep 23, 2011 10:25 pm ]
I normally use the electric grease when I'm reconnecting or doing electrical maintenace, but because the age of my motor I had no plans on working on electrical connections. I guess in the near future I'm going to check and grease all the electrical connections.
Author:  richard nagon [ Sat Sep 24, 2011 7:33 am ]
mercury marine sells a product called corrosion guard. its a spray i like it.
Author:  dog walker [ Sat Sep 24, 2011 8:32 am ]
I've had it happen once before, scraped the fuse with my knife and it fired right up.
Author:  duckduckboom [ Sat Sep 24, 2011 8:36 am ]
Author:  robertb4wd [ Sat Sep 24, 2011 5:01 pm ]
Author:  garjacker [ Sun Sep 25, 2011 8:34 am ]
Dow 111 noncureing silicone. its alot heavier than most dielectrics and can hold up to higher temps without melting off.
