It is currently Thu Jul 10, 2025 4:07 pm
Reply to topic  [ 35 posts ]
 27 kholer godevil surface drive
Post 27 kholer godevil surface drive
I have been tryinf to figure out how i might gey some more horses out the motor. Or upgrade the notor, can anyone give me any help with i might be able to get in order to get maybe more speed and power? Also what would be the best prop to run
Mon Sep 26, 2011 2:58 pm
Post Re: 27 kholer godevil surface drive
Three blade prop for starters. After market exhaust,30hp carb and either 30 hp heads or better yet 18 hp sent to Midwest cub to be reworked for the 27
Mon Sep 26, 2011 6:55 pm
Where coukd i get those from?
Mon Sep 26, 2011 7:15 pm
here ya go but give them a call and tell him about how much more hp u want and he will gladly tell u which way to go cause my buddy just ordered some stuff from him and make sure u let him no its for a mudmotor!! and the 3 blade prop dont work so good in the mud a buddy has one on his gdsd and he cant wait for it to wear down LOL http://www.mcssl.com/store/midwestsuper ... gine-parts
Mon Sep 26, 2011 7:24 pm
Post Re: Re: 27 kholer godevil surface drive
1850 & 36pd
Mon Sep 26, 2011 8:36 pm
Yeah . The ch18, 20 or 22 heads can be reworked to fit the 27 and will increase your horsepower by roughly 2.
Also I love my 3 blade on the godevil . I have less vibration , more speed and don't a problem in the mud.
Sat Oct 01, 2011 7:54 am
1746 with a modded 35 gdsd
Capt Team total asalt
Sun Oct 02, 2011 10:53 am
You'll notice a big gain in power and load carrying ability with just the carb and muffler addition
Sun Oct 02, 2011 1:32 pm
Where can i get the 30 hp carb from and will i onlu need one?
Tue Oct 04, 2011 1:44 pm
mid west super cub has them. You will need to change your intake also for that carb to work.
I would do heads before carb, but that's just me.
Tue Oct 04, 2011 2:36 pm
Just talked to midwest cub today and julian told me that just a carb will give better responce when you give it gas but thats about it , if you want more horse's out of it you need to change the crank from a 2.64 to 3 inch crank and rods a pistons with a carb that has a ajustable jet this will give you WAY more torqe out of it , gonna go this route after duck season with my 27 but I'm gonna do it all heads, cam crank. pistons basicly all of it,just to see how it is , could sell it but like it is but it's only money right and if it not what I want then I buy a 35.
Tue Oct 04, 2011 4:33 pm
Dude, if you are gonna spend that much money, why not get a new powerhead? You are gonna spend almost what a new powerhead would cost and still not be anywhere close to the same cc's. Keep the kohler as a spare.
Tue Oct 04, 2011 4:35 pm
Tue Oct 04, 2011 4:45 pm
No, I'm saying ditch the small block kohler. Get a big block kohler, or briggs, or a genny. You can probably get a stage 1 genny for less than you are gonna spend on just the upgrade on the lil kohler and have a platform you can get a lot more power out of.
Tue Oct 04, 2011 4:47 pm
Tue Oct 04, 2011 4:51 pm
Pistons and rods are almost 600 bucks, the crank is over 700 before balancing. Your gonna want a different cam which is another few hundred bucks...headwork... Your gonna have 3000 in that thing quick...
I believe the crank height is the same. You would need to verify that, but I'm pretty sure that is correct. If you have a MB, you may dig around for some info on the BPS forum. They are coming out with a line of generac motors.
Tue Oct 04, 2011 4:55 pm
Thanks cb If I would have thought this out right the first time I would have bought a 35 in the first place but to late I'l stick with what I got for now gonna check out the one's your talking about for sure so I don't fuk up agian.
Tue Oct 04, 2011 5:00 pm
You didn't fuck up. The kohler is a good lil engine. If it is close to the right HP for your needs, you can do a few things to really help with load carrying and make it that much better. If you are gonna spend several thousand dollars on it though, I would say you are better off getting a bigger platform.
The generac is about the same weight as the kohler, but is capable of building a looot more hp and they are not very expensive. I don't know what the price points are gonna be with the BPS engines, but you can get a 33hp Genny brand new for close to a grand. Looks like BPS will have a cam, rods, pistons, carb kit, and exhaust on the market for them in the near future. From what I "hear", you are going to want to put a carb kit and exhaust on it right outta the gate, but you should be able to do that and still come out right around 2 grand. This way you have a motor with a solid 35 or so hp, looots of torque, still have room to build more power if you want it, and you get to keep your kohler as a backup engine should you ever have any trouble later on down the road.
Tue Oct 04, 2011 5:33 pm
Tue Oct 04, 2011 5:45 pm
I used to have a 27 Kohler motor, and have been through the whole build up process. While it is possible to build one up, it really isn't economical when you compare it to buying a 35/36. I mean, it would be one thing if you had a little 23 block and weight was a big issue, but theres really not a lot of weight difference between a Briggs 36 and a Kohler 27. So the best thing for you to do, is take that money you were going to spend on mods, sell your Kohler, and buy a 35 Briggs. Its not worth the money to try and mod it..... Especially when you consider time spent. And I promise, if you mod it, you will more than likely not get it right the first time.
24x60 Dual Prodrives
Tue Oct 04, 2011 5:53 pm
If you're planning on getting a bigger boat in the future, I promise you'll be much happier getting the Briggs 35 now. It'll be cheaper in the long run, guaranteed.
......... This from a guy who has been there, done that.
Tue Oct 04, 2011 5:55 pm
Tue Oct 04, 2011 6:01 pm
If you can spend less than a grand and be happy, I'd say go for it. The problem is you don't know if you'll be happy until you do it, and you will not get your money back on mods if you decide to sell and start over.
On the bigger boat that you are looking at, I would say you are much better off spending your money on a bigger block. Briggs, kohler, generac, pick your poison. The briggs will probably be the best "bolt on" option if you do not want to mod it right away. The kohler is an expensive motor and you may want a carb upgrade soon after the purchase. The generac is a very well built motor, and very inexpensive, but you will likely want to ditch the stock exhaust and carb set up right out of the gate. Granted, you can do this and still spend less than you would spend on a briggs.
In talking to the guys that run the genny's, they don't "turn up" like the briggs engines, even with mods (unless you get pretty extreme with it anyway) ,but they are very reliable once you get them right and they run well. You could PM Dog Walker or brlcla. They are both running genny's and seem to be really happy with them. Both of them had issues with briggs blocks...
Tue Oct 04, 2011 6:18 pm
I noticed that my base plate has a different set of hole that are spaced out from where my motor is mounted so I'm thinking that mudbuddy has already set this up for a different motor wonder if it's for a 35 van gaurd that would be good.
Tue Oct 04, 2011 6:36 pm
Probably the van. I THINK the genny has the same mounting as the kohler.
Tue Oct 04, 2011 6:39 pm
Tue Oct 04, 2011 6:45 pm
It's about the same size as the kohler, just has the ability to build a lot more power. You might call BPS and see what they got going on. Do a search on here also. Few guys here have picked them up for right around 1000.
Tue Oct 04, 2011 6:50 pm
Best bet for reliable performance straight out of the box is a 35 Briggs block. No mods or parts added. Been proven way too many times.
Tue Oct 04, 2011 6:52 pm
Tue Oct 04, 2011 6:55 pm
What do you guys know about velocity stackers with the k&n filter? Would this be a lityle bit of help? I talked to
Julian from midwest and he told
Me that it would give me a little bit of sumthin
Wed Oct 05, 2011 10:20 am
With an exhaust and heads it will help some. Don't think it's gonna do much for ya all by itself.
Wed Oct 05, 2011 11:05 am
I have an exhausy already, and wad plannin on doin heads after this hunting season, just tryin to do little things that dnt require much work righy before hunting season
Wed Oct 05, 2011 11:15 am
Go for it. Certainly won't hurt.
Wed Oct 05, 2011 11:16 am
ebay has the 40hp gennys for under 1700.
1436 custom walked slowly by a 13hp Homemade LT.
The second amendment is what makes the first amendment possible.
Thu Oct 06, 2011 8:05 am
If he went to a 35 from the 27 wouldn't he also need to go with a different ratio of pullies?
Russ
Thu Oct 06, 2011 10:17 pm
Users browsing this forum: No registered users and 104 guests
