It is currently Thu Jul 10, 2025 2:25 pm
Reply to topic  [ 13 posts ]
 louisiana special problems
Post louisiana special problems
has anyone running this motor had the bolts back out of the belt housing that attach it to the back of the block mine did with 170hrs screwed up all the hole and have had to get the cover repaired and does anyone have any suggestions as to what i can do to prevent this again thank for any input guys
16x56 epidemic slick bottom with mini 4000
Mon Sep 26, 2011 6:06 pm
Post Re: louisiana special problems
either you can lock washer it or put a small amount of loctite
Mon Sep 26, 2011 6:15 pm
riding with my buddys last weekend before the bolt came out the upper gear housing on the mag 45 is bigger in width than my louisiana special alowing for easier access to the bolts mine u have to remove all componets of lower unit to tighten up these bolts think i will use lock washers and lock tight does anyone know the bolts for these small inner mounting holes
Mon Sep 26, 2011 6:26 pm
Mon Sep 26, 2011 6:30 pm
thanks andy do u happen to know what size they are
Mon Sep 26, 2011 6:47 pm
Mon Sep 26, 2011 6:52 pm
did ya happen to get the length on them bolts bud
Tue Sep 27, 2011 3:38 pm
No hadnt forgot, just been busy today. They are 1.75" long.
Tue Sep 27, 2011 4:05 pm
thanks
Tue Sep 27, 2011 4:59 pm
thanks guys for all the help i think i found the root of all my problems while pulling my rear case plate off saw the block move back all 4 mounting bolts where loss i think this caused the bolts to vibrate and back out of the block from the belt housing they b tight now and the motor is back up and ready to run sunday on caddo wish me luck that she holds together again thank everyine for the help :D
Tue Oct 04, 2011 7:58 pm
A friend of mine had the same problem with his! first time it sheared two bolts and backed the other two out enough to tear up the belt and pully. Second time it broke the case. It seemed as if their was a lot of tension between the case and the case cover. when it broke the second time you could see a 3/16 gap between the crank case and the belt housing. Soo this go round he made sure to lossen the 4 block bolts, pull the motor to the housing, and then retighten. We shall see.
Tue Oct 04, 2011 8:11 pm
get some bolts you can run tie wire or commonly called airplane wire though the head tien two to gather. i would also use lock washers two
Sun Oct 09, 2011 9:34 am
Sun Oct 09, 2011 10:09 am
Users browsing this forum: No registered users and 108 guests
