It is currently Thu Jul 10, 2025 4:34 am
Reply to topic  [ 6 posts ]
 Gator tail power trim
Post Gator tail power trim
Probably time to replace it from what it is doing but trying to fix it rather than just replace it.
The power trim hums like it is working but the shaft doesn't move. While the engine is in gear or neutral running or not will still do it.
The funny part is it will do this for say 15 minutes or so then you get aggravated with it come back couple minutes later and works like a charm.
Any idea as to why it does this? And any ways to fix it with out replacing?
1650 ribbed abused by a Gt-35 and push pole reverse
Wed Sep 28, 2011 1:12 pm
Post Re: Gator tail power trim
Sounds like it is low on fluid? Have you checked it?
Wed Sep 28, 2011 1:27 pm
Where can you actually check it? If you back out the allen screw that is on the starboard side back it will let oil out.
Wed Sep 28, 2011 1:32 pm
http://www.gator-tail.com/pdfs/GT%20Own ... %20PDF.pdf
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Sep 28, 2011 2:28 pm
who would have thought haha thanks, now whats the trick to removing it?
Wed Sep 28, 2011 3:55 pm
also seems to act up everytime i trailer it
Wed Sep 28, 2011 4:01 pm
Users browsing this forum: No registered users and 109 guests
cron
