Gros'bec
Joined: Sat Jul 23, 2011 11:36 am Posts: 235 Location: Louisiana
 What's the proper way to ajust valves on stock Briggs 35hp?
I want to ajust valves on stock 35 Briggs. Should I ajust the gap on both intake and exhaust valves with piston at the top of it's stroke or should I open exhaust valve all the way and ajust intake and then open intake all the way and ajust exhaust? Also , is the gap supposed to be set at .004 . It looks simple enough but I want to know the right way and posably get some good tips.
_________________ 18x44 Gator Trax, Stage 2 Mudbuddy
Wed Sep 28, 2011 5:09 pm |
the gator
Joined: Tue Sep 06, 2011 5:23 pm Posts: 190 Location: Patterson,LA
 Re: What's the proper way to ajust valves on stock Briggs 35
Try to get in touch with Calen at Calens engine service.But it is .004 and remove spark plugs and roll engine until the piston stops at tdc and then roll it till the just starts to move down.set the valves on that cylinder,and then do the other.
_________________ 35gtr Stage 1 On 19'3"x46" Mad man Hull going Places far and beyond
Wed Sep 28, 2011 5:28 pm |
cb5331
.004-.006, 1/4 past tdc on the compression stroke, per briggs
Wed Sep 28, 2011 5:40 pm |
deadbird8
Wed Sep 28, 2011 10:54 pm |
Gros'bec
That's what i need to know. Thanks. I love this forum
Thu Sep 29, 2011 4:25 am |
deadbird8
Thu Sep 29, 2011 5:25 am |
po po mud duck
Joined: Wed Jun 30, 2010 7:13 am Posts: 317 Location: Port Arthur TX.
This has always worked for me when setting valve lash on 4 cycle engines.
*Exhaust valve starts to open set intake *Intake valve starts to close set exhaust
Rotate the crankshaft until the exhaust valve begins to open, adjust the intake valve by loosening the adjusting nut slightly until you feel lash on the rocker arm. Now you can set the lash on the intake valve. Spin the intake rocker nut down with the correct thickness feeler gauge inserted between the valve stem and the tip of the rocker arm. Tighten the adjusting nut until there’s a slight drag when moving the feeler gauge.
To adjust the exhaust valve, rotate the crankshaft until the intake pushrod opens the intake valve all the way, then begins to close. With the correct feeler gauge, adjust the exhaust rocker nut using the same procedure as with the intake rocker above. Repeat for each cylinder.
_________________ Casey
Thu Sep 29, 2011 8:28 am |
Gros'bec
Great info guys. I really appreciate it
Fri Sep 30, 2011 9:37 am |
cb5331
I usually set them the way briggs says to and double check them the way that yall do it.
Fri Sep 30, 2011 4:42 pm |
Gros'bec
I have read when setting on top dead center of the compression stroke, to set the intake .004-.006 and setting exhaust to .007-.009 makes a little more power and less chance of burning a valve. Anyone ever heard of this? Also, should I use any type of thread locker on the lock nut?
Fri Sep 30, 2011 8:47 pm |
Gros'bec
Got it done. Set both valve .004 . Just past top dead center. Cranks up fast and runs perfect.
Sun Oct 02, 2011 10:21 pm |
