It is currently Thu Mar 28, 2024 6:30 am
Reply to topic  [ 186 posts ]  Go to page 1, 2, 3, 4, 5  Next
 GTR prop spins in neutral
Post GTR prop spins in neutral
I am new to the GTR 35, but I remember reading that having too much oil in the transmission can cause the prop to spin while in neutral. I just changed the oil in my transmission(looked well overdue) and noticed that the prop spins. How do I know if I have the right amount of oil in the transmission?
17'3" Cat 5 Center Console with a GTR 35 with Cam, Rockers, Pushrods, Black Death, Mikuni, K&N, BPS Twins
Sun Oct 09, 2011 2:00 pm
Post Re: GTR prop spins in neutral
When you fill it I think the 2 holes should be at 11 o'clock and 3 o'clock. Add oil in the top until it comes out the bottom hole. You may also want to change the grease in your shaft if you haven't.
Sun Oct 09, 2011 2:12 pm
Oil has nothing to fo with it!! The grease in the lower unit might need to be changed !!
17x48 extreme stage 2 GTR
Sun Oct 09, 2011 4:25 pm
I checked the oil level, and greased the lower unit this afternoon and the prop still spins. I noticed it is actually spinning in reverse. Is it possible that caliper is still engaged? How would I check that?
Sun Oct 09, 2011 5:30 pm
Take the cover off and look to see if the pads are still grabbing or rubbing the plate without the reverse handle engaged.
Sun Oct 09, 2011 5:35 pm
mine has always spun in neutral. It spins just as fast as if it is in gear. It will slow down when it is in the water but also still has enough force to push the boat forward while in netural. I just learned to deal with it. I would like to know a solution to it also.
18x54 xtreme huntdeck 35gtr
camo designs custom paint
Sun Oct 09, 2011 5:44 pm
Put yer face in the myrtles.
Sun Oct 09, 2011 6:43 pm
Maybe a tight belt could cause this?
16x44 Hanko Skiff
35GTR
Sun Oct 09, 2011 6:50 pm
Sun Oct 09, 2011 6:53 pm
All the Shit yall give GD owners about nuetral and yall dont even have it? :lol: :lol:
Sun Oct 09, 2011 7:25 pm
MMT Moderator
My prop spins a little. It's nothing like a fully engaged prop. I've bumped my prop once & so has my dog with it running in neutral. In both instances neither one of us was hurt or bleeding. The prop will stop if something is introduced.
GTB 1860 w/ 2019 GTR40XD-HO
Sun Oct 09, 2011 7:30 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Oct 09, 2011 7:35 pm
Sun Oct 09, 2011 7:37 pm
Sun Oct 09, 2011 7:58 pm
The difference is when its spinning in nuetral I can stop it with my foot without losing it,just saying.
Sun Oct 09, 2011 8:03 pm
"Secret is in the grease"
:lol: :lol: :lol: :lol: :lol:
Sun Oct 09, 2011 8:12 pm
Sometimes my spins in neutral, sometimes it doesn't. I changed the fluid in the planetary gear twice, that didn't seem to make a difference. I have noticed when you put fresh grease in, it doesn't spin. Does any of the mud buddy motors do this? And don't even compare this to a gdsd, that thing is bolted direct. Try bumping into that prop while the engine is running. Dog walker, 11 and 3??? Your drain scews on the planetary gear line up different than mine?
1754 Gatortail Extreme / 35 GTR
Sun Oct 09, 2011 10:25 pm
Mine did this once. It was because I'd tightened the clutch bolt too tight & it was putting enough friction on the plate, the gear was turning. Once I loosened it a lil bit it quit. No problems since.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Oct 09, 2011 11:46 pm
Mine has spun since day one. Here is what I KNOW to cause the issue.... It only spins if you have a GTR, Non reverse models wll NOT spin in neutral.
Too much transmission oil will cause "extra fluid coupling" kinda like an Auto tranny torque converter.. the fluid will cause the outer ring of the transmission to spin around the crankshaft extension of the transmisison. This
Lower unit grease is probably the BIGGEST thing to a fast spinning prop in conjunction with the Too much trans oil, becasue the fluid coupling effect wants to spin the belt, if your grease is older/ lost thickness the prop will spin faster.
Also you will eventually lose some grease out of the seals over time because thats what happens with normal wear anbd heat cycles with Rubber seals riding on metal wear sleeves. Air pockets can be present in the shaft that need to be worked out over time. When I rebuilt my lower unit I hande packed the Needle bearing and the roller bearing then I pumped grease into the shaft to fill it up. Upon instal the prop did not spin in neutral at all, but once I ran the motor a couple ours in the marsh it began to spin faster becasue the grease was filling all the nooks and crannys between the shaft, tube, and bearings. So keep the grease in the shaft full but dont over fill becasue too much pressure will push the seal lips out. the right amount of grease will keep the spinning to a minimum.
Unless you take one of these apart you probably dont get what I am saying, but it is a quite simple concept. Good luck getting your rig ready!
Mon Oct 10, 2011 6:46 am
MMT Moderator
I'd add that I wouldn't add grease to the lower unit without opening up the drain screw first. That way you never run into that pressure issue you mentioned?
Mon Oct 10, 2011 8:08 am
Mon Oct 10, 2011 8:16 am
Post Re: Re: GTR prop spins in neutral
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Oct 10, 2011 12:28 pm
I have a GTR and mine spins slowly forward
16x44 Hanko Skiff
35GTR
Mon Oct 10, 2011 12:40 pm
Mon Oct 10, 2011 1:08 pm
Camo's post is out in left field.... LOL The fluid coupling of the trans pulley spinning around the cranks shaft is whats making it sin in neutral. In an NON reverse model there is only a clutch, so therefore the crankshaft can spin freely without the pulley spnning.
Mon Oct 10, 2011 1:39 pm
Actually boys, I've dealt with both, but no, I'm no GTR FE like yall. I'd forgotten that he said it was spinning in rev, that's why I corrected myself in that last post. The prop CAN spin in fwd on the non reverse motors, but like I said, when it does, it's usually an indication of a problem or issue that needs to be addressed. ;)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Oct 10, 2011 7:53 pm
Well I came to the board to see why my new 2011 GTR with 2 hours spins in neutral hard enough to push me into my dock. Looks like I'm not alone. Guess I'll have to treat it like the race Merc outboards and kill the engine for neutral!
It would be nice if the gator tail crew would comment.
Mon Oct 10, 2011 9:25 pm
Mine usually doesn't spin very much in neutral when it's in the water. Maybe one of us should contact Hoyt and just ask. I'll call tommorrow and then post what I find out. But I think I know wha he's going to say.
Tue Oct 11, 2011 2:00 am
Tue Oct 11, 2011 5:18 am
Tue Oct 11, 2011 5:19 am
Tue Oct 11, 2011 5:42 am
Tue Oct 11, 2011 5:45 am
First off you got a 2011 motor and you come to the www to get a problem solved!! Do like the other thousands of customers that are not on mmt and call Gatortail!! I bet they can help you way better than here!!
Tue Oct 11, 2011 5:50 am
How many hours you got on your motor!! What is your service plan on it!! How many times you added grease and what kind of grease!!
Tue Oct 11, 2011 5:53 am
He probably hasnt done much service to it, seeing as it only has 2 hours on it.
Tue Oct 11, 2011 6:02 am
Tue Oct 11, 2011 6:11 am
Tue Oct 11, 2011 6:28 am
Guy buys new MM - then comes to forum and asks a pretty good basic question...
[youtube]http://www.youtube.com/watch?v=S2oymHHyV1M[/youtube]
Tue Oct 11, 2011 6:52 am
Tue Oct 11, 2011 7:17 am
Giga quit startin shit. Terry was asking that question to the original poster. He asked a question and Marcus answered it. Got Dux, the only thing I would add is, when new the transmission comes with grease in it. Once you purge it out with oil after the break in and put the correct amount of oil in as per owners manual. The prop does not spin as much. Also a smaller lighter boat will notice it alot more than a larger one. When changing the oil, remove both screws and drain empty. (the 1st change will require forcing the grease out with oil) Then position the screw holes at 1 & 7 o'clock. Fill with oil till oil comes out the bottom hole, this is all the oil needed. (anymore will cause excessive prop spin or blow out the seals of the transmission) Replace screws and your done. I do mine every 50 hours with my oil change.
Tue Oct 11, 2011 7:38 am
Users browsing this forum: No registered users and 224 guests
