It is currently Thu Jul 10, 2025 4:13 pm
Reply to topic  [ 8 posts ]
 Gt 23 no loaded power!!!!
Post Gt 23 no loaded power!!!!
I have a gt23 on a 1648 rivited Jon boat and with me 6 gallons of gas and battery I'm getting like 17-18 mph on gps but when I put one guy 200 lbs and probably another 100 lbs of gear the boat only does 4-7 mph that doesn't sound right to me could it be a prop issue the prop still measures 10 3/4 inches but I have no way to tell if the cup is worn down if anyone has any advice or experience with this kinda set up please let me know
Wed Oct 19, 2011 7:43 pm
Post Re: Gt 23 no loaded power!!!!
What were your RPM's
Do the motor and boat transom hieghts match?
Wed Oct 19, 2011 8:18 pm
Measure your prop from tip to tip your good if your around 115/8 to 12inches or more, problem may be else where. sounds like prop cause if your only running 17-18 with just you thats a little low should be in the low 20's. Maybe someone else can chime in! What are your Out Of Water(OOW) Rpm's and what are your In water Rpms while your driving?
Wed Oct 19, 2011 8:21 pm
Ya transom heights match and my rpms in water are 3500 and out are 3600
Wed Oct 19, 2011 8:50 pm
Rpms should be much higher may need to adjust throttle linkage
Wed Oct 19, 2011 9:34 pm
ya you have something not right, you should tune it up to about 4000 or 4100 out of water ..
Gave up hunting ducks and started underwater basket weaving!
Wed Oct 19, 2011 9:52 pm
I have a 23 GTR on a 1748 dry weight 450# 20 inch trams. 6 gallon gas tank up front trolling motor batt. In back. Prop 11 3/8. By myself. 22 mph. Son 130#. Daughter 75#. Trolling motor 40#.and myself 19 mph. On gps. All stock . Hope this helps.
Thu Oct 20, 2011 5:42 pm
Sorry. Forgot the RPMs. 3350 RPMs best speed. Out of water. 4300 rmps
Thu Oct 20, 2011 5:46 pm
Users browsing this forum: No registered users and 109 guests
