It is currently Thu Jul 10, 2025 4:12 pm
Reply to topic  [ 12 posts ]
 Pro-drive props and exhaust
Post Pro-drive props and exhaust
Can anyone tell me info on a Hopkins prop for a prodrive? Does it help the motor perform better?
Also, I nned a new muffler, but I would like to get a stainless or something else besides a stico muffler. Can I get some I ideas on this or is there a muffler out there that is better than the other?
Thanks for any assistance.
Sat Oct 22, 2011 9:26 am
Post Re: Pro-drive props and exhaust
Search feature works wonders. Lots of threads about hopkins props and lots of threads about exhausts.
An exhaust by itself isn't gonna do much for performance. I personally would recommend the stock prop for a stock motor. PD put a lot of R&D in to make a prop that works well with their engines. May look in to a hopkins if the motor was highly modded and you were turning too many rpm's.
Sat Oct 22, 2011 11:08 am
go hopkins pd had hopkins do the props at first
driving a gd in ur lake
and i aprove this message
Sat Oct 22, 2011 12:17 pm
Guest I could of been a little more clear. I was looking for info on performance with the Hopkins prop compared to the stock prop. Thanks for the input guys. Any one else on the prop?
What about a stock muffler or stainless muffler, or something else that could possibly give a little help on performance?
Sat Oct 22, 2011 8:06 pm
BPS and Marshmellow make stainless higher flow exhausts for the verticals. The exhaust by itself is just the base for performance improvements. The engine is an air pump - more air in / more air out. A higher flow exhaust helps with the second part.
Sun Oct 23, 2011 12:01 am
For a stock motor, keep the stock prop......
Like DB8 said, by itself the exhuast will not buy you any additional performance. Add either carb, heads, or cam and heads and it will really wake the motor up.
WC Custom 1854
Sun Oct 23, 2011 7:24 am
Sun Oct 23, 2011 7:49 am
PD prop is best on a stock motor. If they would make a 13 pitch prop I would have it on my motor instead of the Hopkins. PD has a very good prop.
18'x54"CC Hanko/ 36PD
Sun Oct 23, 2011 10:18 am
what pitch is stock
Sun Oct 23, 2011 1:45 pm
You can for sure get a Hopkin's Cleaver to perform better than the stock pd prop!You are going to have to get him to build it for your setup.You will not get it right the first try most of the time!
Sun Oct 23, 2011 2:33 pm
I will stick to the stock prop and probably the marsh mellow exhaust. I mainly want it cause the stock muffler only lasts me 2 years. Most of my hunting is in salt marsh and rusts pretty quick. But would a cold air intake be the carb mod I would need to add with this exhaust.
Sun Oct 23, 2011 5:50 pm
WC Custom 1854
Sun Oct 23, 2011 7:08 pm
Users browsing this forum: No registered users and 107 guests
