It is currently Thu Jul 10, 2025 2:19 pm
[ 3 posts ] |
Jw261
Joined: Sat Oct 22, 2011 12:20 pm Posts: 96 Location: Lower Alabama
 Fuel prob
I have a 16 hp vanguard lt. I have new gas and it cranks strong but will not run unless I drop gas into the top if the carb. I did have some fuel leaking from the omc fitting at the tank and thought it might not be getting a good siphon. Was wondering if this motor relies on the siphon or if it has a pump? I took the omc fitting off and placed it directly into the fuel tank and tried to pump fuel in. Still didn't work. I took the air cleaner assembly off and I see fuel in the carb but don't know if it's enough. Any ideas???
Sat Oct 22, 2011 12:27 pm |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
 Re: Fuel prob
it has a fuel pump. vacume
Sat Oct 22, 2011 1:54 pm |
Jw261
 Re: Fuel prob
Carb cleaner did the trick. Now I got a loud squeal coming from the prop.
Sun Oct 23, 2011 4:48 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 105 guests |
