sela_native
 powertrim will only work while running
Title says it all, had the previous problem with it not moving just humming fixed (low fluid)
now the damn thing wont even hum while the engine is off im getting power all the way to the trim unit, but only way to get it to move or work is to turn the engine over and it will trim down but to get it up i have to rev the engine.
Anyone ever see this?
_________________ 1650 ribbed abused by a Gt-35 and push pole reverse
Thu Oct 27, 2011 4:26 pm |
Goose Crumpler
Joined: Thu Dec 02, 2010 9:51 am Posts: 1404 Location: Northern Wisconsin
 Re: powertrim will only work while running
What brand of motor would be helpfull
Thu Oct 27, 2011 4:44 pm |
sela_native
sorry always forget, gatortail 35
Thu Oct 27, 2011 4:51 pm |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
sounds like your gettin low voltage
Thu Oct 27, 2011 4:53 pm |
sela_native
im reading 12.4 at the black/blue and green/white connections
Thu Oct 27, 2011 4:55 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
Hows your fluid level?
_________________ Put yer face in the myrtles.
Thu Oct 27, 2011 5:01 pm |
sela_native
just replaced it for the second time in a month
Thu Oct 27, 2011 5:02 pm |
quackconsumer
Check your connections at the switch?
Thu Oct 27, 2011 6:45 pm |
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
Either bad connection at the switch or Bad switch. Similar thing happened to mine in less than 10 hours and it was the switch.
Mine is similar to a regular toggle switch on center console vs the rocker switch like on the tiller handle
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
Thu Oct 27, 2011 7:03 pm |
sela_native
Ill put it back out tomorrow and check the connections address the wire splice.
And willett did your switch still put out volts when pressed or pushed?
Thu Oct 27, 2011 7:12 pm |
willett
Never checked with a meter. Mine would only work when it wanted to. It would go down most of the time just fine, but very rarely would go up.
It happened like second day of real season and I had an old rocker switch from a winch and hooked it up and it worked perfect. It's actually still on there right now.
Thu Oct 27, 2011 7:19 pm |
sela_native
Well I have an extra toggle switch laying around so wouldn't hurt to try it. Thanks ill update after
Thu Oct 27, 2011 8:48 pm |
retired and broke
Giga, told you'll to buy some switches before the duck season started.
Thu Oct 27, 2011 9:19 pm |
sela_native
Really? Thanks for the informative post broke!
Now on with the real problem.
Fri Oct 28, 2011 6:12 am |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
I've seen a bad switch not let you move in one direction or the other, work intermittently but never only work with the engine running. Could be the switch or connection
Fri Oct 28, 2011 1:37 pm |
sela_native
traced everything, ended up pulling the electrical off the trim motor and found a broken spring like action that connects the armature to the electrical motor, put in another like spring and seems to be holding great. Thanks for all the input and help
Fri Oct 28, 2011 8:54 pm |
Curly
Joined: Tue Aug 03, 2010 1:59 pm Posts: 90 Location: Guntersville, AL
glad to hear you got it fixed. Btw how many hours have you got on that motor?
Fri Oct 28, 2011 10:51 pm |
