| setting Valves???...help! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=2355 |
Page 1 of 2 |
| Author: | DUCKSBANE [ Tue Jun 02, 2009 1:43 pm ] |
| Post subject: | setting Valves???...help! |
I am getting my heads back any day now from EVT. Can one of you guys walk me through setting the valve clearance? And do you know of a good link with pictures? Oh, and please talk to me like im retarded. Thanks Dave |
| Author: | craig [ Tue Jun 02, 2009 1:56 pm ] |
| Post subject: | Re: setting Valves???...help! |
PM Matt. |
| Author: | DUCKSBANE [ Tue Jun 02, 2009 2:00 pm ] |
| Author: | coondik [ Tue Jun 02, 2009 2:03 pm ] |
| Author: | craig [ Tue Jun 02, 2009 2:05 pm ] |
Matt is Matt. |
| Author: | DUCKSBANE [ Tue Jun 02, 2009 2:24 pm ] |
| Author: | craig [ Tue Jun 02, 2009 2:35 pm ] |
Matt also knows how to set valves. |
| Author: | DUCKSBANE [ Tue Jun 02, 2009 2:40 pm ] |
| Author: | stanco [ Tue Jun 02, 2009 2:49 pm ] |
get you one of these: http://www.briggsandstratton.com/maint_ ... pid=274041 Local Books a Million or Barnes and Nobel have them in stock (at least they did in Texarkana a few years ago). Pretty good info in there, valve clearance, timing key, carb stuff, etc. |
| Author: | Jamie B. [ Tue Jun 02, 2009 2:57 pm ] |
Coondik pretty much sumed up the process |
| Author: | Matt [ Tue Jun 02, 2009 3:23 pm ] |
http://www.allmudmotors.com/blogs/how-t ... 5-vanguard Thats the link I was talking about. |
| Author: | DUCKSBANE [ Tue Jun 02, 2009 4:11 pm ] |
| Author: | deadbird8 [ Tue Jun 02, 2009 4:27 pm ] |
| Author: | DUCKSBANE [ Tue Jun 02, 2009 6:10 pm ] |
| Author: | mudd [ Tue Jun 02, 2009 7:13 pm ] |
| Author: | deadbird8 [ Wed Jun 03, 2009 12:07 am ] |
| Author: | coondik [ Wed Jun 03, 2009 5:24 am ] |
| Author: | J Wales [ Wed Jun 03, 2009 6:10 am ] |
Here's a pretty good video showing the process: http://www.youtube.com/watch?v=hGkn0jR9RJM |
| Author: | deadbird8 [ Wed Jun 03, 2009 3:47 pm ] |
| Author: | stanco [ Wed Jun 03, 2009 8:03 pm ] |
| Author: | coondik [ Wed Jun 03, 2009 8:30 pm ] |
[quoteWHAT IS THAT SUPPOSED TO MEAN?][/quote] jus an ol' sayin' round deez parts, it means exactly what it reads kinda like an ol' washed up ball player who's a coach now, NO HARM PODNAH |
| Author: | deadbird8 [ Thu Jun 04, 2009 5:22 am ] |
| Author: | River [ Thu Jun 04, 2009 6:50 am ] |
| Author: | coondik [ Thu Jun 04, 2009 6:55 am ] |
| Author: | River [ Thu Jun 04, 2009 8:00 am ] |
| Author: | coondik [ Thu Jun 04, 2009 8:11 am ] |
| Author: | DUCKSBANE [ Fri Jun 05, 2009 7:20 am ] |
| Author: | coondik [ Fri Jun 05, 2009 7:24 am ] |
| Author: | DUCKSBANE [ Fri Jun 05, 2009 9:07 am ] |
| Author: | coondik [ Fri Jun 05, 2009 9:16 am ] |
pick up a harmonic dampner puller from any auto parts store and that should do tha trick. |
| Author: | Jamie B. [ Fri Jun 05, 2009 9:47 am ] |
Place a slight bind on the backside of the flywheel and tap center nut with 2# maul it comes right off i did that to mine with 300 hours on it, came right off |
| Author: | deadbird8 [ Fri Jun 05, 2009 11:09 am ] |
The head install and timing key are not dependent on each other. You can install the heads and run it and do the timing key any time. I did the key later and ended up removing it (didn't need it). |
| Author: | DUCKSBANE [ Fri Jun 05, 2009 11:42 am ] |
| Author: | Jamie B. [ Fri Jun 05, 2009 11:58 am ] |
I found that the timing key mad the motor come alive not saying that it helped speed wise but it made a difference on throttle response |
| Author: | craig [ Fri Jun 05, 2009 12:12 pm ] |
Advancing the timing will give you an increase in throttle response. |
| Author: | DUCKSBANE [ Fri Jun 05, 2009 12:23 pm ] |
| Author: | DUCKSBANE [ Fri Jun 05, 2009 12:26 pm ] |
| Author: | craig [ Fri Jun 05, 2009 12:31 pm ] |
It is noticable. |
| Author: | deadbird8 [ Fri Jun 05, 2009 12:45 pm ] |
| Author: | DUCKSBANE [ Fri Jun 05, 2009 1:08 pm ] |
I didn't notice much on my motor- but it ran hot out of the crate. Well I better advance it cause mine was a lot of things out of the crate and hot wasnt one of them. |
| Page 1 of 2 | All times are UTC - 6 hours |
