heads?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=24460
Author:  spiky208 [ Tue Nov 29, 2011 12:33 pm ]
Post subject:  heads?
been looking at doing heads and wanted some input on what seams to work and what does not. Iv got a guy that can do anything to the heads that I want him to, now i just need to know what to tell him to do. the motor is a stock 2011 36hp pro drive. I would also like to get a exhaust, the exhaust doesn't have to be the loudest by any means i just want a exhaust that will help my motor.
Questions,
what do I tell the guy to do to my heads? tell it to me like you would tell it to him.
port and polish,
install stainless steal valves,
and take how much off ?
lapping?
what exhaust would be a good one? I'm not looking to be the loudest, just wanting good performance.
is the BPS Q a good one?
also, my prop is pretty worn, I can always run 4100 rpms even when i trim down a lot. after i get a exhaust and heads and kn air filter, what prop should i get? should i go with the stock prodrive prop? 12-12 or go to something else?
thanks guys
Ray
Author:  spiky208 [ Tue Nov 29, 2011 3:42 pm ]
Post subject:  Re: heads?
motor is bone stock.
Author:  Mudhead [ Fri Dec 02, 2011 11:01 pm ]
Author:  balloon-knot [ Mon Dec 05, 2011 11:22 am ]
Deck my heads .050" Then raise the valves .030", There is alot of clearence btwn the valve and piston. The net effect on the rocker is only .020" So there are lots of threads left for adjustment.
Author:  THE TANK [ Mon Dec 05, 2011 11:47 am ]
Author:  balloon-knot [ Mon Dec 05, 2011 12:49 pm ]
Talking apples and oranges! I am talking valve clearances. You are talking valve lash. I set valve lash to .005” which is a middle of the road setting.
Search "valve lash" in the engine forum. Lots of discussion around this in there.
Author:  spiky208 [ Mon Dec 05, 2011 2:32 pm ]
ended up just ordering IM heads, carb, mm muffler.
hoping it all comes in today or tomorrow so i can get it all put together before the splits over.
any advice or tips on installing the carb and mm muffler and heads? iv got a mechanic buddy who can help me with the heads.
Ray
Author:  oncall [ Mon Dec 05, 2011 4:09 pm ]
Get a carb bracket from Autogateman.
Author:  spiky208 [ Mon Dec 05, 2011 4:36 pm ]
will the carb just fall off? seams like it should stay in position, and i would expect it to when coming in a kit for my motor? whats the deal and why are the carbs coming loose?
thanks
Author:  MaXXis85 [ Mon Dec 05, 2011 4:40 pm ]
the only thing that really holds the carb on is the rubber boot and a hose clamp.
Author:  DuckHunterF250 [ Mon Dec 05, 2011 4:41 pm ]
Author:  OwenDickeson [ Mon Dec 05, 2011 6:23 pm ]
If you run stumps, you will need some form of a bracket to hold that sucker on.
This is how mine is nig rigged. Hasnt come off since.
Author:  spiky208 [ Mon Dec 05, 2011 6:27 pm ]
are there different brackets for holding carbs on a PD? is there a way to rig it with some stuff from lowes or is autogatmans support the only one?
Author:  OwenDickeson [ Mon Dec 05, 2011 6:28 pm ]
Pretty sure Autos is the only one. I had that one made before he had his out.
Author:  spiky208 [ Mon Dec 05, 2011 6:43 pm ]
how does his hold the carb in place? anybody have a picture?
Author:  OwenDickeson [ Mon Dec 05, 2011 6:44 pm ]
If your gonna buy a Mikuni, do yourself a favor and just buy Auto's brace.
Author:  take'emgator [ Mon Dec 05, 2011 8:33 pm ]
I have a picture i'll post up
Author:  take'emgator [ Mon Dec 05, 2011 8:37 pm ]
This is one I installed on a guys motor for him
Author:  take'emgator [ Mon Dec 05, 2011 8:43 pm ]
This should give u a good idea
Author:  take'emgator [ Mon Dec 05, 2011 8:46 pm ]
First pic is a mudbuddy 5500 application and the second one is on my GTR 35, both are the same setup. I broke my first carb support and if not put on right you can easily put them in a bind.....has saved me a lot of headache when hitting big obstacles underwater that use to knock my carb off. I have a thicker bracket now which is what Rod(autogateman) is selling in his kits.
You won't regret it, it can only help your motor.
