It is currently Sat Jul 12, 2025 11:38 pm
[ 3 posts ] |
ducks19
 6.5 briggs upgrades?
i have a 6.5hp briggs intek surface drive and its my first mud motor, i was wondering if anyone could give me some pointers on maintenance like how often to change the oil on it. when should i switch spark plugs and such. And i really want to turn it up a little bit to get it creating a little bit more power, is there anything that could help such as better spark plug or air filter,muffler etc with little cost involved? Any help would be greatly appreciated.
Thu Dec 15, 2011 11:05 pm |
Woodiebuster
 Re: 6.5 briggs upgrades?
I can tell you anything you wanna know about that motor!
For changing the oil, there is a square headed bolt on each side of the bottom of the block, you can take it off with a cresent wrench or a 12 point 9/16 wrench/socket. I recommend doing it about every 50hrs of run time.
For spark plugs, there is really no gain in performance with them and you rarely have to change one, keep a couple OEM replacements just to eliminate part of an ignition problem if you ever have one.
Also, that's a pretty poorly designed motor... Don't fork with more performance or you'll be buying a new short block.
What kinda frame is it on?
Fri Dec 16, 2011 5:02 pm |
ducks19
It's on a Dixie frame. I appreciate the info on the motor that helped me out a lot.
Fri Dec 16, 2011 6:33 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 85 guests |
