It is currently Sat Jul 12, 2025 4:50 pm
Reply to topic  [ 2 posts ]
 18 HP Vanguard on Go - Devil
New Member
Post 18 HP Vanguard on Go - Devil
I am having trouble with the engine powering up fully when the prop is submerged. When out of water the engine, cranks and runs well, by sound you cannot imagine a problem until putting the prop in water and the engine still runs properly just does not fully power up to get boat on plane. I had the carburetor replaced and all new fuel lines and fuel filter the first of November. We did get some gas with some water in it. We have disposed of this gas, gotten new gas added a fuel additive run for approximately 2 hours and are still having problems. The only thing else I have noticed is that the self lubricator on shaft is cracked a leaking a little grease, is this related to the problem? Does the shaft build up pressure that puts the load to the engine. When I first got out of shop for first month of season it ran great! Any thoughts and suggestions would be greatly appresciated so I can back to trying to bang some ducks while on christmas break.
Thanks
Mike
Wed Dec 21, 2011 4:02 pm
Post Re: 18 HP Vanguard on Go - Devil
Make sure itnis getting fire to both cylinders and do a compression check on both cyl.
Wed Dec 21, 2011 6:31 pm
Users browsing this forum: No registered users and 126 guests
