It is currently Tue Jun 24, 2025 6:45 am
Reply to topic  [ 88 posts ]  Go to page 1, 2, 3  Next
 CDI's any leaking crank case gaskets yet?
Post CDI's any leaking crank case gaskets yet?
Anyone with a Vanguard CDI experiencing any leaking at the crank case gasket yet? If so, how many hours? Did Briggs address this issue and solve it? Report in regardless of what type of motor your running...PD/GT/GD/MB. I'm curious.
Crisis defines character
Thu Jan 05, 2012 5:37 pm
Post Re: CDI's any leaking crank case gaskets yet?
The cdi and non cdi use the exact same block, crankcase cover, and gaskets. Why does it matter if you have a Briggs Marine motor or not?
Thu Jan 05, 2012 5:40 pm
Thu Jan 05, 2012 5:45 pm
Yes they still leak its the same thing
Thu Jan 05, 2012 5:48 pm
Sorry, but there is nothing "new" about the Marine or CDI as you call it.
Briggs offers the "Marine" motor as an option for the external parts on the motor, but there is nothing new about the block at all. The marine motor has differnet coils, wiring, charging system, and muffler. Briggs still uses the exact same block for both the marine and the standard motor (which some manufacturers still sell).
Thu Jan 05, 2012 5:57 pm
Mine started to leak at about 150hrs. At 233hrs its no longer leaking. But I am using rotella now instead of Briggs 30wt
I gave up mud motors
Thu Jan 05, 2012 6:04 pm
Mine leaked at around 120 hrs, then I dropped a cam in, now it's at 200 and not leaking yet
Thu Jan 05, 2012 6:11 pm
Let me clarify this again, these manufacturer's want to charge $7k- $8K for a new motor depending on how you option it. Regardless, I wanted to know if Briggs has addressed the issue-different bolts, different gasket or whatever. I know the block is the same and if they have resolved it or attempted to resolve it, the CDI motors being the latest released are the testing ground. I would have thought by now Briggs would have been able to be address it. To be honest, for the price of these motors I find it to be concerning it hasn't been addressed. Mine started leaking around 100 hours, and mine is a 2006 and one of the first 50 to come out. It would be nice for someone to come up with a solution IMO.
Thu Jan 05, 2012 6:12 pm
Still same block and same bolts (bolt length has varied on a few model numbers). Believe the gasket has changed since 06, but not sure. Either way, it appears they still have the same issue. There is still a weak point where the oil ports are and it is proned to leaking in that area.
Is yours still leaking?
Thu Jan 05, 2012 6:59 pm
Yes it is.
Thu Jan 05, 2012 7:09 pm
Thu Jan 05, 2012 7:33 pm
Every Briggs I have seen began leaking at the case gasket at between
50 and 100 hours.... Good news is that the aftermarket gasket holds up
much better.... Mine was leaking slightly by 70 hours and the aftermarket
gasket that went in is over 100 hours and has not leaked at all yet....
Thu Jan 05, 2012 7:45 pm
Thu Jan 05, 2012 8:07 pm
What is involved with changing out the gasket? Which one are you finding that doesn't leak?
Thu Jan 05, 2012 8:10 pm
Thu Jan 05, 2012 8:17 pm
Thu Jan 05, 2012 8:21 pm
Thu Jan 05, 2012 8:24 pm
Nothing yet has been found to completely stop it on a pd. my buddies was leaking after 50 hrs on a stage 1 with EVT gasket and arp studs
Thu Jan 05, 2012 8:49 pm
My GTR started leaking at 62hrs
Gator tail
Thu Jan 05, 2012 9:06 pm
mine started about 100. changed it and installed a cam in the beguining of the duck season, it started agin last week after about 40hr... looks like a prob im gonna have to deal with.. I hear the Boat Dr. does a little somethig diff and it holds up pretty good... I may try it out.
GatorTail 18x54 extreme Center Console 37EFI "Ole Man Rig"
Thu Jan 05, 2012 10:45 pm
You should quit bitching and get a kohler if you are that worried about it
1848 Prodigy
35 GTR
Fri Jan 06, 2012 12:22 am
Mine leaked stock at 75 hours, and had it replaced. My cam wiped a lobe so I modded my motor, and about 30 hours later its leaking. been leaking ofr the last 10-12 hours of run time. My block/ frame on the starboard side is Damp with oil. its my form of preventing saltwater corrosion.
Fri Jan 06, 2012 7:49 am
BoatDr, are you having better luck than the 30-50 hours these other guys are having? You using the torque sequence the Gary has posted a few times, right? Anything else done differently? Sealants, loctite?
Fri Jan 06, 2012 9:53 am
Sat Jan 07, 2012 3:04 am
Sat Jan 07, 2012 9:59 am
MMT Moderator
Mine leaked once around 100 hours and SETX Performance changed mine out while doing the mods (cam), no leaks yet. 250 hours & counting
GTB 1860 w/ 2019 GTR40XD-HO
Sat Jan 07, 2012 10:43 am
The Briggs motor is not made for the amount of vibration. Since mud motors are a small part Briggs business. They haven't addressed it yet.
18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Sat Jan 07, 2012 1:15 pm
Sat Jan 07, 2012 2:50 pm
For reference:
Sat Jan 07, 2012 2:52 pm
Andy did mine a few years ago and I've put about 100 hours on it now. It just started leaking again but to be fair, I recently found 3 out of 4 of my motors mounts loose where the engine bolts to the PD plate. So I'm assuming that vibration is what caused it because it was pretty darn loose and wobbly.
FYI - all Prodrive owners should periodically check the tightness of those main engine mounting bolts.
Sat Jan 07, 2012 9:06 pm
I agree it will take a case redesign. Sheet gaskets are way too limited to fix this problem.
I like to use a thin layer of Permatex 2A, the black molasis stuff, on sheet gaskets. That combo has worked great for me on industrial process equipment like compressors. Anyone else tried that combo on this problem?
Sun Jan 08, 2012 7:00 am
Sun Jan 08, 2012 7:53 am
I cleaned up the gasket surfaces on the case with an Emory cloth, put a thin layer of gasket sealer on each side, and used the torque sequence that Gary posted. So far so good, but I only have 75 hours since then.
Sun Jan 08, 2012 8:14 am
roughening it up a bit with the emery cloth and rtv should help
Sun Jan 08, 2012 8:58 am
About 90 hours on original gasket without drop of oil leaking. I installed cam and heads at 90 hours and am at 50 hours on new gasket without drop of oil. But then I usedd a torque wrench measuring foot lbs instead of inch lbs. Dem bolts are tight tight.
Sun Jan 08, 2012 10:06 am
Don't put em to tight and strip the aluminum
Sun Jan 08, 2012 10:45 am
Mine has been leaking since 50 hours. Got 110 now and have no intention of changing it till it's leaking like the engine n my old 1985 chevy truck.
18'x54"CC Hanko/ 36PD
Sun Jan 08, 2012 3:24 pm
Keep checking the bolts as others have said. I found one a little loose and leaking in this same area.
Sun Jan 08, 2012 3:47 pm
Sun Jan 08, 2012 5:49 pm
Mon Jan 09, 2012 5:21 am
