It is currently Sun Jul 13, 2025 8:51 am
Reply to topic  [ 20 posts ]
 Oil Cooler
Post Oil Cooler
thinking of replacing my oil cooler and mounting a new, bigger cooler on the fan cover, or in the stock location (during the summer i would think a cooler on the fan cage would introduce more hot air into the block) as i have seen on other machines. what are some advantages to this? any disadvantages?
Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Fri Jan 06, 2012 11:49 am
Post Re: Oil Cooler
http://www.mudbuddy.com/forum/oil-coole ... 13930.html
check this thread out. basically unless you are running a stage 3 motor (BPS 45+++) it is not really necessary. But still interesting none the less
1848 Prodigy
35 GTR
Fri Jan 06, 2012 5:58 pm
Post Re: Oil Cooler
You sure about that. I got a stage 2 and i watch hot a$$ smoke coming out my oil release hose. Only happens when im turning 4500 rpms. I was told its a good idea.
Fri Jan 06, 2012 7:35 pm
Post Re: Oil Cooler
its a very good idea, I did a idle test the other day on mine with and with out bigger oil cooler. 10 minute intervals @ 75 degrees ambiant temp, was a 12 degree cooler difference with it on.
Fri Jan 06, 2012 7:52 pm
Post Re: Oil Cooler
1848 Prodigy
35 GTR
Fri Jan 06, 2012 8:06 pm
Post Re: Oil Cooler
Fri Jan 06, 2012 8:28 pm
Post Re: Oil Cooler
1848 Prodigy
35 GTR
Fri Jan 06, 2012 8:55 pm
Post Re: Oil Cooler
Fri Jan 06, 2012 9:05 pm
Post Re: Oil Cooler
mine is the stock cooler mounted in front of the fan. i can run wfo and you can hold your hand on the cooler. try that in the stock location. I have bps cam, im heads, mikuni, and twin exhaust
Fri Jan 06, 2012 10:28 pm
Post Re: Oil Cooler
Fri Jan 06, 2012 10:51 pm
Post Re: Oil Cooler
stock size, i beleive its 3/8"
Fri Jan 06, 2012 10:58 pm
Post Re: Oil Cooler
Fri Jan 06, 2012 11:29 pm
Post Oil Cooler
Yep
Sat Jan 07, 2012 7:29 am
Post Re: Oil Cooler
Lets heat up the air that cools the engine :?
Sat Jan 07, 2012 10:18 am
Post Re: Oil Cooler
Sat Jan 07, 2012 10:29 am
Post Re: Oil Cooler
Sat Jan 07, 2012 10:40 am
Post Re: Oil Cooler
Gonna see how this works. Went and ran it this morning WOT for a few miles. Could put bare hand on cooler. And I like the idea of stacking stock coolers.
Sat Jan 07, 2012 2:18 pm
Post Oil Cooler
That's exactly how mine is and it works great!
Sat Jan 07, 2012 2:37 pm
Post Re: Oil Cooler
Sat Jan 07, 2012 6:26 pm
Post Re: Oil Cooler
Sat Jan 07, 2012 7:35 pm
Users browsing this forum: Majestic-12 [Bot] and 99 guests
