Oil leak/fitting http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=25584 |
Author: | GSUrugger [ Sun Jan 08, 2012 8:56 pm ] |
Post subject: | Oil leak/fitting |
Maybe someone can answer this. I have a leak at the return fitting located on the lower side of the oil filter flange. How in the world does this fitting come off? its worn out and loose as it is, but I can't unscrew it bc of the block... |
Author: | mizzippi jb [ Sun Jan 08, 2012 8:58 pm ] |
Post subject: | Re: Oil leak/fitting |
may have to cut the 90 off and get one with a straight flange. Check to see if they make em first. |
Author: | JIMMY W [ Sun Jan 08, 2012 9:05 pm ] |
That piece that it is screwed into should unscrew just like the oil filter! |
Author: | GSUrugger [ Sun Jan 08, 2012 9:10 pm ] |
Author: | dfou [ Sun Jan 08, 2012 9:40 pm ] |
Author: | deadbird8 [ Tue Jan 10, 2012 7:05 am ] |
Simple fix. Remove the oil filter and then use a large wrench to unscrew the piece the oil filter screws into to take the flange off the block that the oil filter seats on. When the flange is off, remove both those 90 degree pieces and coat with sealant and reinstall tight with the 90's pointing in the right direction. Then put the flange back on the block (oil the o-ring between the block and flange before reinstalling). |
Author: | GSUrugger [ Tue Jan 10, 2012 7:17 am ] |
Author: | Team Camo [ Fri Jan 13, 2012 8:52 pm ] |
Post subject: | Re: Re: Oil leak/fitting |
