Rev Limiter
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=25766
Author:  FallenDucks [ Sat Jan 14, 2012 11:48 am ]
Post subject:  Rev Limiter
Can I put a electronic rev. limiter on a stock carb? Is there any benefits or neg. of doing this. I am running right around 4000 rpm wide open out of water. I have a purple gov. spring, but the thing that I don't like I have my gov. screw almost cranked tight. the spring that is around the screw looks like it is ready to pop off.
Author:  take'emgator [ Sat Jan 14, 2012 12:15 pm ]
Post subject:  Re: Rev Limiter
You already have a Rev limiter built into the motor. YOu do not need a external rev limiter besides the one you got. No benefit and no negative to adding one
Author:  pooldoo73 [ Sat Jan 14, 2012 1:50 pm ]
If all your turning is 4000 oow, u need to crank that up to 4300 to give a lil more go. The spring will b fine.
Author:  Team Camo [ Sat Jan 14, 2012 4:37 pm ]
^^^^ X2 ^^^^
Author:  deadbird8 [ Sat Jan 14, 2012 6:33 pm ]
Author:  take'emgator [ Sat Jan 14, 2012 9:21 pm ]
I know but he said he has a stock motor which means he did none of that except change a spring out. I know how the rev limiter works, if his motor is stock then he didn't remove the govenor gear.
Author:  deadbird8 [ Sat Jan 14, 2012 11:46 pm ]
Author:  take'emgator [ Sun Jan 15, 2012 6:12 am ]
OF course you can, but what the hell for? A stock motor is not gonna reach a critical RPM, so why would you put a external rev limiter on it......Wow...come on DB8, aren't you SUPPOSE to be some kind of MM guru.
Author:  deadbird8 [ Sun Jan 15, 2012 6:55 am ]
Author:  pooldoo73 [ Sun Jan 15, 2012 6:56 pm ]
U did a good job of explaining that DB8.
Author:  autogateman [ Sun Jan 15, 2012 6:58 pm ]
Oh snap!! Lol
Author:  FallenDucks [ Fri Jan 20, 2012 8:01 am ]
Wow thanks guy's for the info.
Garry I have my throttle set right and I will just get the brown spring and go from there. Thanks for the great info.
