It is currently Sat Jul 12, 2025 6:58 pm
Reply to topic  [ 6 posts ]
 Fuel pump ?
Post Fuel pump ?
I have a 36pd that already had an older fuel pump on it the wires to it have corroded off so im in the market for a new one is there any certain brand thats better than others any help would be greatly appreciated thanks !!!!
1748 SDB being pushed by a 36pd
Wed Jan 18, 2012 7:06 am
Post Re: Fuel pump ?
a facet 41078 is about the best i have found for this application. you can go with the round gold series but dont think its needed. The 40178 has 3ft of dry lift at 2-3 1/2 psi, check valve and anti siphon. right now pegasus auto racing has the best deal cause shipping is free. https://www.pegasusautoracing.com/group ... upID=FACET
I have mine mounted on the motor and since it has 3ft of dry lift it primes itself.
Thu Jan 19, 2012 8:46 pm
where would you ground the wire off and where would you put the hot wire
Thu Feb 02, 2012 9:12 pm
on my 16hp briggs the hot wire is ran to the carb soleniod wire "which was doing nothing anyway" and its grounded where it mounts on the motor. on my 9hp lifan i actually installed a briggs 5 prong switch and run it the same way.
Thu Feb 02, 2012 9:34 pm
Ok so the hot wire on the last pump that was on there was hooked up to the wire that ingauged the prop should I keep it there or should I put ti somewhere else because I always had to use my primer bulb to get the motor to start never could just turn the key and wait a sec and start it sorry if there to much I'm new to this
Wed Feb 08, 2012 11:06 pm
i honestly could not tell you as i have no experience with anything but LTs. but i would want the pump on and primed before i started. so if you are just sitting idle at the boat ramp warming the motor up the pump is not working? I would wire off something that is hot when the ignition is in the on position. Thats why i use the carb solenoid wire. you use your carb solienoid wire? b&s wire configs are all the same. it will be a white wire coming off the switch. try this diagram http://www.tulsaenginewarehouse.com/dra ... wiring.pdf this will help you find a hot wire.
Thu Feb 09, 2012 5:32 am
