Fuel pump ? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=25875 |
Author: | maverick [ Wed Jan 18, 2012 7:06 am ] |
Post subject: | Fuel pump ? |
I have a 36pd that already had an older fuel pump on it the wires to it have corroded off so im in the market for a new one is there any certain brand thats better than others any help would be greatly appreciated thanks !!!! |
Author: | garjacker [ Thu Jan 19, 2012 8:46 pm ] |
Post subject: | Re: Fuel pump ? |
a facet 41078 is about the best i have found for this application. you can go with the round gold series but dont think its needed. The 40178 has 3ft of dry lift at 2-3 1/2 psi, check valve and anti siphon. right now pegasus auto racing has the best deal cause shipping is free. https://www.pegasusautoracing.com/group ... upID=FACET I have mine mounted on the motor and since it has 3ft of dry lift it primes itself. |
Author: | maverick [ Thu Feb 02, 2012 9:12 pm ] |
where would you ground the wire off and where would you put the hot wire |
Author: | garjacker [ Thu Feb 02, 2012 9:34 pm ] |
on my 16hp briggs the hot wire is ran to the carb soleniod wire "which was doing nothing anyway" and its grounded where it mounts on the motor. on my 9hp lifan i actually installed a briggs 5 prong switch and run it the same way. |
Author: | maverick [ Wed Feb 08, 2012 11:06 pm ] |
Ok so the hot wire on the last pump that was on there was hooked up to the wire that ingauged the prop should I keep it there or should I put ti somewhere else because I always had to use my primer bulb to get the motor to start never could just turn the key and wait a sec and start it sorry if there to much I'm new to this |
Author: | garjacker [ Thu Feb 09, 2012 5:32 am ] |
i honestly could not tell you as i have no experience with anything but LTs. but i would want the pump on and primed before i started. so if you are just sitting idle at the boat ramp warming the motor up the pump is not working? I would wire off something that is hot when the ignition is in the on position. Thats why i use the carb solenoid wire. you use your carb solienoid wire? b&s wire configs are all the same. it will be a white wire coming off the switch. try this diagram http://www.tulsaenginewarehouse.com/dra ... wiring.pdf this will help you find a hot wire. |
